Tink-tink Noise In Roof/winshield Area At 65-70 Mph
I'm experiencing this noise (tink-tink) type noise at interstate speed. I can't have the only new body stlye GMC that has this? I think I'm going to make an appointment next week to have it checked out at the dealership. I think it might have something to do with the seal between the top of the glass and the roof, but it doesn't leak.
Fred
PM on the way.
I'm not sure if you got my VIN# as my PM sent box is empty? Anyways the Vin# 2GTEK133771615607
Thanks, Fred
Fred,
I saw this in another post about this same problem. It seems from those posts the the seal around the top left and right side of the windshield loosen while going down the highway. The consensus from some of the members is that its from the bud deflector which may cause this. It may have something to do with aerodynamics?!
One of the options is to use some two way tape to button down those seals around the windshield.
r,/
John,
Are you a USCG instructor? I'm also in the USCG if so.
Anyways, I would like to think GM would have a fix if I were to take it in for this apparent problem.
Fred
looks like you have a bug shield on the front there. i put one on my truck for less then a day when i had to pull of the side of the road and take it off because it was annoying me so bad. the wind deflect right to the top of the window and rattles the window molding.
many people have fixed it by putting silicone around the edges of the molding or something to that effect.
Yep, sorry I went out for new years.........that deflector could be what is causing it......in addition, you have three tsbs on your truck's GMVIS profile..... EI
07082
POWER STEERING FLUID LEAK AT GEAR/RACK, REF-TSB 07-02-32-002C ??
08/14/2007
See Bulletin
EI
07199
RADIO SPEAKER BUZZ NOISE - TSB. 07-08-44-013 ??
07/31/2007
See Bulletin
EI
07321
INNER DOOR PANEL RATTLE NOISE / LOOSE - REF. TSB 07-08-110-010. ??
12/13/2007
See Bulletin
and here are those corresponding bulletins:
Document ID# 2032705
999999995.gifSubject:EI07082 - Power Steering Fluid Leaking from Power Steering Gear/Rack Assembly #07-02-32-002C - (10/19/2007)
Models:2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Denali, Sierra, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
1500 Series Only
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS, otherwise disregard the bulletin and proceed with diagnostics found in the published service information. THIS IS NOT A RECALL. Refer to Service Bulletin 04-00-89-053A for more detail on the use of Engineering Information Bulletins.
This bulletin is being revised to add the 2008 model year and update the information. Please discard Corporate Bulletin Number 07-02-32-002B (Section 02 -- Steering).
Condition
Some customers may comment on a fluid leak. Upon investigation, the technician may find fluid leaking from the power steering system.
What Action to Take
Important: All potential leaks should be completely cleaned and identified before attempting to repair or replace any power steering components.
  1. Start diagnosis by inspecting the fluid level in the Power Steering Reservoir. If the fluid level is NOT low, a careful analysis of the condition is necessary as it may involve a different type of fluid leak.
  2. Visually inspect the components where the fluid has accumulated.
  3. Completely clean off any fluid residue from the suspect components.
  4. Apply tracing powder to the suspect components. This is an effective way to determine the source of a leak. As an alternative, fluorescent dye (such as Kent Moore J 28431-6) may be added to the power steering fluid.
  5. Start the vehicle and allow the power steering system to reach normal operating temperatures.
  6. Turn the steering wheel to the stops in each direction while bumping the steering wheel against the stops 3-4 times. This will build maximum steering system pressure and help identify the source of the leak if present.Tip
    A black light may be used with yellow safety glasses to help pinpoint the source of a leak.
  7. Determine the source of the leak.
  8. If a repeatable leak is found, use the following tables to determine if the condition is repaired and what corrective action is needed.
Repairable Leaks
Source of Leak
Correction
Pressure feed and return hoses/lines
Replace seals, hose, or line set
Power steering pump
Reseal or replace pump if necessary
Cylinder gear/rack lines
Replace O-ring seals or rack lines
Non- Repairable Leaks
Source of Leak
Correction
Porosity leak in the gear/rack housing
Replace steering gear/rack
Leak from tie rod boots
Pinion seal
Repeatable leak at steering gear adjuster plug*
See note below
*If fluid is observed at the adjuster plug during the initial visual inspection, then refer to the following:
• Seepage at the adjuster plug may not necessarily indicate an active leak. Power steering fluid is used during the manufacturing of the gear/rack. The fluid used at assembly is pushed into the pinion area during assembly. The adjuster plug and the area below the pinion are not positively sealed. Fluid trapped in this area during assembly may seep from the adjuster plug. The rack should not be replaced for this condition.
• You can distinguish seepage from an active leak by removing the left tie rod boot clamp and inspecting for the presence of fluid at the inner tie rod.
• If no fluid is found in the left tie rod boot, replace the boot clamp and clean the seepage from the rack. No further action is needed.
• If fluid is found in the left tie rod boot, replace the gear assembly.
Engineer Contact Information
You may contact Engineer Tim Emmitt at 586-492-0278 for additional information or guidance before repairing the vehicle. This call may result in a personal visit to your dealership or a special request to return parts that exhibit unique conditions. In either case, you should receive a response back within 2 hours on what action to take the same business day of your call (Eastern Daylight Time).
If you do not receive a response from engineering, then proceed to repair the vehicle. Use normal diagnostics and claim the repair work under the appropriate warranty labor operation.
GM Engineering is working to determine the root cause of the above conditions. GM Engineering has a need to obtain information during diagnosis and BEFORE repair. As a result, this information will be used by engineering to "root cause" the customer's concern and develop/validate a field fix.
Parts Information
Part Number
Description
15254058
Pipe Kit, Steering Gear
15254059
11562064
Clamp, Crimp
(Boot to Rack)
11562066
Clamp, Spring
(Boot to Tie Rod)
26100863
Seal, Power Steering Gear Inlet and Outlet Hose
26081619
Seal, Steering Gear Cylinder Pipe
(O-ring)
Warranty Information
Important: DO NOT use the labor operation listed below if engineering did not respond.
For vehicles repaired under engineering direction, use:
Labor Operation
Description
Labor Time
E9451*
Engineering Information-Power Steering Leak
0.6 hr
Add
Repair per Engineer Direction
Use Actual Repair Order Clock Time
*This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Document ID# 2001040
999999995.gifSubject:EI07199 - Radio Speaker Buzz Noise #07-08-44-013 - (07/31/2007)
Models:2007 Chevrolet Silverado
2007 GMC Sierra
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS, otherwise disregard the bulletin and proceed with diagnostics found in the published Service Information. THIS IS NOT A RECALL. Refer to Service Bulletin 04-00-89-053A for more detail on the use of engineering information bulletins.
Condition
Important: If the customer did not bring their vehicle in for this condition, do not proceed with this bulletin.
Some customers may comment on a door trim buzz noise during radio speaker operation.
Correction
GM Engineering is attempting to determine the root cause of the above condition. GM Engineering has a need to obtain information first hand during diagnosis and BEFORE repair. As a result, this information will be used by engineering to "root cause" the customer's concern and develop/validate a field fix. Please follow the instructions below regarding the requested information.
If the customer's concern can be duplicated, document the following information in the repair order:
  1. From which area of the door does the buzz originate?
  2. When the buzz is detected, document the following radio settings:
    volume
    bass
    midrange
    treble
  3. Based on the location of the buzz, remove the door trim and search for potential causes. Inspect the speaker connection for a secure fit. Inspect the area behind the door trim panel and insulation cover for loose fittings or components. If the cause is isolated, perform necessary corrective actions to alleviate the buzz.
  4. For dealers located in SE Michigan ONLY between 7:00 a.m.- 4:00 p.m. - contact the engineer (Matt Berg) prior to making any repairs. For all other cases, if the speaker is found to be defective proceed with the repair. Submit a Field Product Report (refer to bulletin 02-00-89-002F) containing all information requested in this bulletin as well as the diagnosis and repair.
For dealers located in the Detroit, MI area ONLY, contact the engineer listed below prior to making any repairs.
Engineer
Phone Number
Location
Matthew Berg
248-891-9302
Detroit, MI Area
Labor Operation
Description
Labor Time
C9803*
Engineering Information - Radio Speaker Buzz
0.7 hr
Document ID# 2045071
999999995.gifSubject:EI07321 - Inner Door Panel Rattle Noise/Loose (Engineering Information) #07-08-110-010 - (12/13/2007)
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard this bulletin. THIS IS NOT A RECALL -- refer to TSB 04-00-89-053A for more detail on the use of Engineering Information bulletins.
Condition
Some customers may comment on any of the following conditions:
a rattling noise coming from inside the door or the door panel
a poor fit of the inner door panel
a loose door panel
Cause
GM Engineering is attempting to categorize the several different types of customer comments occurring with door panels on the fullsize pickup and SUV's. This information will be used to quantify each type of specific concern and develop/validate fixes.
During diagnosis and repair, note the following information on the repair order:
Important: If the vehicle is located in SE Michigan, please contact Jerod Long at 586-899-2549. An Engineer may need to physically inspect the vehicle prior to it being repaired.
  1. Describe the customer concern - be specific.
  2. Does the vehicle currently exhibit the condition, or can the condition be easily seen?
  3. Provide a detailed description of the condition causing the customer's concern.
  4. Describe the repair made to correct the customer's concern.
  5. Fax the front and back of the completed repair order to:Attn: Jerod Long
    Fax #: 586-575-0520
For vehicles repaired under Engineering direction, use:
Labor Operation
Description
Labor Time
C9827*
Door Panel - Engineering Information
0.4 hr
Add:
to repair other side
0.2 hr
* This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
Hope this additional info helps if you are having more than just the tink noise in the roof/windshield area.........
I guess it wouldn't end up bothering me so much if I hadn't bought the bug deflector from GM..
Anyways, I guess I'll throw a bead of silicone around the top of the windshield.
I appreciate the informed help and hope you all had a happy New Year.
Fred
Fred
Been reading posts my new style Silverado has the samr rattle from same area. Doesnt do it all the time. I think wind direction plays a role.
Also mine made the noise before I added bug deflector or visors
Al
Fred
Al
Hello. I have had this on my old 2005 Silverado, on my new 2007 Sierra, and my wife's 2007 Tahoe and her old 2002 Trailblazer. The dealer told me that it was my bug guard (Which was incorrect as it did it even after I took it off). They told me this on all three of these vehicles, probably because they hate to troubleshoot rattles and it is easier to blame someone elses product than their own. They actually fixed it on the trailblazer but all that they did is remove the trim and re-stick it down.
Here is my fix, it worked on all of the vehicles above. Clear silicone caulking. Running along the glass on the "A" Pillars there is a piece of trim about an inch wide. That is what is making the noise. Run a bead of caulk below the trim so that it contacts the glass as well as the trim.
Hope that helps.
B
Condition
a loose door panel
Cause
    Fax #: 586-575-0520
Labor Operation
Description
Labor Time
C9827*
0.4 hr
Add:
0.2 hr
Thanks for posting this. Both of my back door panels (crew cab) are loose. I haven't had to bring my truck back to the dealer yet, but when I do I will be sure to mention this TSB.
