Pulls To The Right In 4wd
My 99 CC DRW 4X4 pulls hard to the right only when in 4X4, Tires are the same side to side and no other odd issues just when 4x4 is engauged.
Anyone have any ideas, Its freezing cold here and this pig don't fit all the way in the garage lol.
  • 4 weeks later...
Your truck should have a steering stablizer shock. It is probaley worn out. Get a new one from superlift or rancho it is better than the stock and will hold up better if you have bigger tires. You can also add a second one on. Superlift had a single add on that works with the OEM steering stablizer set up.
I had the same problem. With bigger tires it got worse. I replaced the OEM with one from superlift and also add the dual steering stablizer to help out. NOTE: I had to custom fit the dual steering stablizer because it is suppose to be only used with thier lift kit.
