Tbi Hard Start And White Smoke
OK to start out I have a 1987 K5 Blazer with the stock 350 TBI. The other day I had driven about 100 miles or so on the highway with it and everything was fine. Pulled in the driveway shut it off and did things at home. About 4 hours later I went to start it up and it cranked over but no fire.
The check engine light was on and still no fire. After repeated atempts it did fire and it smelled of fuel badly. Smelled like it was flooded. The smoke however smelled like rotten fuel. Lean maybe?
I cleaned the TBI out with cleaner and wiped crud away from the area. I tried it again tonight and it did the same thing. This time a huge cloud of smoke came from the engine and it was the same foul smelling white smoke. It drove home (.5 miles) and it sits in the drive till I figure out what to do with it.
I have a buddy coming over in a day or 2 with a code reading machine. Doubt it will pinpoint a problem for me though. Anyone have ideas for me?
It's 21 years old. It can drink and vote let it smoke if it wants too.
haha, funny. I actually laughed out loud with that one.
  • 3 months later...
That's pretty easy... next time you do it, pull a spark plug. If it's wet, it's too rich, and that would confirm the problem. A white smoke indicates either unburnt fuel, or you have a water leak into the cylinders. I had a 91 gmc jimmy with the 4.3 tbi and 297,000 on the original drivetrain (my first car) and it would constantly flood.
If it's a fuel problem check the fuel press. regulator or the injectors (most common causes)
    d.lowrey
    d.lowrey
  • Who's Online   5 Members, 0 Anonymous, 2,287 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
