Unidentified Connector Behind Panel
Decided I'd take the panel off the dash today to install cig lighter socket. I get the panel off, disconnect the two existing lighter socket connectors, and I see one connected into the rear of the little storage area that's between the lighters.
I pulled that, and it was connected to nothing, almost like it was put there just to keep it outta the way. It just snaps into place.
Does anyone know what this is for? This is on an '07 NBS Sierra WT 4x4 5.3 Ext Cab
I knew also that those sockets would be in there some wierd way. I see that getting them outta there will require 4 special tools, ancient incantations, 2 spells, and perhaps some persuasion from my wife.
Thanks
Rick
That's where the stabilitrac button goes, the plow button, and something else that I have forgotten. Look in your manual it shows 4 buttons there if you have those options.
I was gonna ask the same thing when i pulled out my stereo.
Ah, Stabilitrac, the anti-fun driving mechanism..... :D
Thanks
Plow button is if you get the factory added plow option - I guess it's a switch to lift and lower the plow. I think the heated mirrors button goes there too but I don't remember.
the plow switch doesn't actually have anything to do with a plow. its a prewired switch with the plow prep package. the switch is to control a strobe. there is supposedly a wire up above the headliner that can be retrieved from the third brake light. You can wire a safety strobe to it.
I have two buttons in there. Stabilitrac and heated washer fluid. The other that are avalible are Pedal adjustment and Ultrasonic backup asist
Here is something that may help:
Cigar Lighter Receptacle or 12-Volt Accessory Power Receptacle Replacement
Tools Required
J 42059 Cigar Lighter Socket Remover
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1709072&psdid=1647&evc=sm#ss1-1709072">
Removal Procedure
    <LI type=1>Remove the auxiliary power outlet fuse from the fuse block. <LI type=1>Remove the receptacle:
2.1. Look into the receptacle. There are two 3 mm (0.11 in) tab windows 12 mm (0.47 in) from the front of the receptacle. The
J 42059 pushes the plastic latches from these tab windows and the receptacle can be pulled straight out.
2.2. Place one side of the "T" portion of the
J 42059 into the tab window. The J 42059 will not fit straight into the receptacle. Angle the J 42059 slightly for insertion into the receptacle.
2.3. Insert the other side of the "T" into the opposite tab window.
You must move the J 42059 handle toward horizontal to engage the other tab window.
2.4. Use the
J 42059 to pull the receptacle straight out.
If J 42059 tool fails to release the lighter socket from the retainer, perform the following alternate method:
3.1. Insert a small grinding tool with a cutoff wheel into the socket.
3.2. Remove the plastic latches in the 3 mm (0.11 in) square windows.
3.3. Use the
J 42059 as directed above to remove the socket.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1709072&psdid=1647&evc=sm#ss2-1709072">
Installation Procedure
    <LI type=1>Route the connector through the retainer. Align the accessory power receptacle retainer to the slot in the opening. <LI type=1>Install the retainer by pressing into place fully seated. <LI type=1>Connect the electrical connector to the receptacle. <LI type=1>Align the tabs on the receptacle to the slots in the retainer. Install the accessory power receptacle by pressing into place until fully seated.
  2. Install the accessory power receptacle fuse.
Stupid question, where are your lighter sockets? (The below pic is too confusing for me)
The main components of your instrument panel are the following:
  1. <LI type=A>Air Outlets. See
Outlet Adjustment .
<LI type=A>Turn Signal/Multifunction Lever. See Turn Signal/Multifunction Lever .
<LI type=A>Driver Information Center (DIC) Buttons. See Driver Information Center (DIC) .
<LI type=A>Hazard Warning Flasher Button. See Hazard Warning Flashers .
<LI type=A>Instrument Panel Cluster. See Instrument Panel Cluster .
<LI type=A>Shift Lever. See Automatic Transmission Operation . Tow/Haul Selector Button (If Equipped). See Tow/Haul Mode . Range Selection Mode (Allison Transmission and Hydra-Matic® 6-Speed Button (If Equipped). See Automatic Transmission Operation .
<LI type=A>Audio System. See Audio System(s) .
<LI type=A>Instrument Panel Storage Area. See Instrument Panel Storage Area .
<LI type=A>Integrated Trailer Brake Controller (If Equipped). See Towing a Trailer .
<LI type=A>Exterior Lamp Controls. See Exterior Lamps .
<LI type=A>Hood Release. See Hood Release .
<LI type=A>Parking Brake. See Parking Brake .
<LI type=A>Dome Lamp Override Button. See Dome Lamp Override . Dome Lamp Knob. See Dome Lamps . Fog Lamp Button (If Equipped). See Fog Lamps .
<LI type=A>Cruise Control Buttons. See Cruise Control .
<LI type=A>Tilt Wheel Lever. See Tilt Wheel .
<LI type=A>Horn. See Horn .
<LI type=A>Automatic Transfer Case Control (If Equipped). See Four-Wheel Drive .
<LI type=A>Ashtray (If Equipped). See Ashtray(s) and Cigarette Lighter .
<LI type=A>StabiliTrak® Button (If Equipped). See StabiliTrak® System . Ultrasonic Rear Park Assist Disable Button (If Equipped). See Ultrasonic Rear Parking Assist (URPA) . Pedal Adjust Button (If Equipped). See Adjustable Throttle and Brake Pedal . Heated Windshield Washer Fluid Button (If Equipped). Windshield Washer .
<LI type=A>Accessory Power Outlet. See Accessory Power Outlet(s) .
<LI type=A>Climate Control System. See Climate Control System and Dual Automatic Climate Control System .
<LI type=A>Power Take Off (PTO) Control (If Equipped). See Power Take Off (PTO) in the Duramax Diesel Supplement Index.
<LI type=A>Passenger Airbag Off Control (If Equipped). See Airbag Off Switch .
Glove Box. See Glove Box .
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
