I Dont Know What This Fuse Is For .
I have a 1998 chevy 1500 4.3 V6 . There is a 1.75 fuse in the fuse block on the inside of the truck . Anyway I was checking the fuses and the 1.75 fuse is blown . I bought the truck used and I dont have a owners manuel to tell what this fuse is for . Thank you all for any help you can give me . Everything works , engine runns smooth , check engine light is OFF . I replaced this fuse with a new one , I just wanted to know what it was for , Thank you
Anybody ??
IF it was in a fuse holder of its own, it was probably added by a previous owner for an accessory. Alarm, etc. that may have been removed. Removal of these items is hardly complete in many cases. See if it has power going to it. If so I would trace it to see where it goes.
If it is in the OEM fusebox, still check it and see if it has power to it. Might have just been a blown fuse that got stuck in a spare socket.
Here is the underhood for the 4.3:
Document ID# 1470190
1998 Chevrolet Chevy C Pickup - 2WD
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1470190&pubid=51&evc=sm#oth1-1470190">
FIGURE Cell 11: ECM-1 Fuse - 4.3L©
Document ID# 303635
Circuit Protection - Fuses
The fuse is the most common method of an automotive wiring circuit protection. Whenever there is an excessive amount of current flowing through a circuit the fusible element will melt and create an open or incomplete circuit. Fuses are an one time protection device and must be replaced each time the circuit is overloaded. To determine if a fuse is open, remove the suspected fuse and examine the element in the fuse for an open (2). If not broken (1), also check for continuity using a DMM or a continuity tester. If the element is open or continuity is suspect, replace the fuse with one of equal current rating.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=303635&psdid=51&evc=sm#tab1-303635">
Fuse Types
Current Rating Amperes
Color
Auto Fuses, Mini Fuses
2
Gray
3
Violet
5
Tan
7.5
Brown
10
Red
15
Blue
20
Yellow
25
White or Natural
30
Green
Maxi Fuses
20
Yellow
30
Light Green
40
Orange or Amber
60
Blue
50
Red
J-Case Fuses
20
Blue
30
Pink
40
Green
50
Red
60
Yellow
Document ID# 303635
I dont see anything for 1.75 at all for your year from the factory.......
I was wrong it was a 7.5 AMP Fuse . It is in the fuse block on the drivers side fuse panel . The cover for it probally had a diagram on the back of it . Thanks for the replies .
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
