Copper Core Plugs
I know the hype about irridium and platnum spark plugs but I know that in race cars and nascar they use copper plugs like NGK and run better...they say that the copper plugs burn more efficient and for 2$ a pop cant go wrong. Last about 32,000 miles, and let you advance timing without spark knock.....anyone else got any imput...
i have always used coppers .. (NGK) ... and have no complaints about them ... to me the only reason to use the plats or the other junk is for if you dont feel like changing out the plugs every 25k miles or so ...
I thought I read on this site one or more of the tuners actually suggesting changing to a copper plug as the platinums/iridiums were running rough (I think) with the tune. I see you have a Wait4Me tune. Why not see what they suggest for a plug. I believe they were one of the tuners suggesting copper NGK plugs. I think I recall they had a specific gap suggested as well.
yeah I remember someone suggesting that as well just couldnt find the post...the plug for the LS1 type engine is TR55 but should I use the stock gap? Jesse @ wait4me suggested the same thing...He said the coppers with the tune and eliminate pinging
hmm well all cars i have changed over to coppers i normally go up about .020 from what the gap is listed on the sticker ... (less it is already in the .060 range) ..
and always have ended up with a smoother idle .. and what seems to be nicer accel .. without the choppy feeling ... kinda hard to explain till you try it yourself ...
Anyone know why GM went from 0.060" to 0.040"? According to AC Delco and NGK they are suggesting the smaller gap for all plugs (iridium, platinum, and copper).
I just posted the same question in a new topic! sorry about that, but I also would like to know. I too use the NGK coppers.
most of the auto manufactures ... the only excuse i have been able to get is to help with emissions .. and to keep the cath converter from burning out...
I believe all of these choices are COPPER centers with just a difference in tips...platinum for longer life and iridium for the ability to make a thinner tip...anyone see anything different???
Bill
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
