Just Bought A 99 Silverado
I just bought my Silverado the other day and it has a 5.3l v8 with a Whipple supercharger on it. Should I use supreme gas with the supercharger or does it make a difference? I've called Whipple a few times and left messages but nobody has called me back yet. I haven't even put gas in it yet since the tank was full when I drove it off the lot.
Absolutely, anything that raises compression requires the highest octane you can get.
Yeah, that would probably be smart to use premium.
Thanks I was hoping that I could still use regular to save money but it's nott that much of a difference I guess. Now if I can just figure out what the yellow button on my dash goes to Ill be alright.
DON'T PRESS IT!!! At least not until you reach precisely 88 MPH. :eek:
already tried it when i was driving her home unfortunately nothing happened, does anyone know where i can find a new flux capacitor
Home Depot, aisle 5, right next to the Plutonium.
Lol!!!!! You the man vmax
And yeah I'd go with premium
Can I go to Lowes? It's closer.
I too think premium fuel is a must. Boost needs good fuel.
can I bother you by asking how much you paid and how many miles it has on ?
thanks and hope you like it :)
got it for 10k walkout price and it has 103k miles on it
I'll get some pics up as soon as it stops raining for more than 10 mins.
I don't know how much boost I'm running yet. Whenever I can get someone at Whipple to answer the phone I'm gonna get more info on it.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
