Driver Information Center, Tahoe 03
tahoe_norway
Hi.
On my Tahoe 2003 5,3L, the Driver Information Center (driving computer) is living it's own life. It's changing the language settings when it feels like it, it's re-setting the trip counters when driving and dosen't always respond to the buttons on the steering wheel. When setting the driving center to the instant fuel usage option, it suddenly jumps back to odometer or a re-set trip counter. Lately I have observed that the driver information display is on after the engine and ignition are turned off. At this time the dispaly is alternating between the hourmeter, odometer and a strange message like: OP-DL 5462 CAL, AC (something like that, didn't rembemer exatcly), and then goes black before it start the same again. I think this is going on all the time when the car is not running (and probaly eating my battery)
On an onther forum it has been suggested that this could be realted to a grounding issue, either to the frame or negative battery.
Any ideas to what this could be? My Norwegian dealer have no idea what this could be and they can't find anything wrong.
Thanks for your help
Regards Truls
Hi.
You said it all when you said 2003 - It's a bad cluster and will be "good will" repaired by a GM dealership. Contact them and have them look up a TSB for this. Even European dealers should know about this.
Regards Truls
Hi.
Regards Truls
Thanks for this answer. I'll tell this to my dealer. I have searched several TSB's and have found issues regarding gauges not working because of the cluster but not the driving computer. Have you seen a TSB describing my issue?, an if you have, where can I find it?
Thanks for helping me out. The US Car community in Norway is rather small due to very high governmental taxes on cars with large engines and high weight on the car, so it is very nice for the enthusiasts here in Norway to ask questions in an US forum :tear: .
Regards Truls
  • 3 weeks later...
I recently bought an 03 suburban and I noticed that the DIC is not responding to the steering wheel buttons. My OD works, trip OD works, hour meter works, and it responds when I change Driver memory position. It just wont respond to any of the steering wheel controls (can't access fuel economy, oil life, etc.) I read somewhere that there is a fuse hidden somewhere behind the instrument cluster (?). I appreciate any feedback. Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
