Tires And Wheels
Well i just bought this truck its a 96' z71 and i have many ideas of what i want to do with it but so many decisions are making it hard for me so i need some help. I am for sure going with the 6 inch suspension lift with 35 inch tires but i have no clue what wheel size to go with. I want the new revolutionary look with the big wheel big tire design but being a older truck i dont want the wheel to be to big i was thinking around a 16 or 17 inch wheel. Does anyone have a nice wheel or size i should go with?
If your going to upgrade brakes at any time I believe a 17" or bigger wheel is needed. That's about the only thing I would change so I could put bigger rotors on. But a couple of yrs ago there a was very little in choice of 17" tires.
  • 1 month later...
that is right.
17" look better too, but 16 tires and wheels are way cheaper (depending on what you go with)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
