In Motion Navigation
My wife has a 2006 GMC Envoy Denali with the single slot for bot nav and cd. It is the XM Onstar Bose system. Is there a hack out there to use the nav while in drive? I have a 300C SRT8 and just spent $20 on a nav disc that allows me to do this. I still can't believe we paid so much for the nav on this thing and can't even listen to a cd while the navigation disc is in, not to mention no bluetooth. I've searched the forum and haven't found anything. I checked that coastal site, but they offer the lock pick for 2007 and up. Plus I'm not willing to spend $250 for it especially since we don't have the dvd option in it.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
