JayDog Posted February 11, 2008 Posted February 11, 2008 In the market to purchase a new Chevy truck for the family construction business. I am trying to determine the pros and cons of buying a 3/4 ton vs. a 1 ton. Either truck will have the 6.0 and single wheel rear axle (on the 3500) crew cab with long bed. Is there a large difference in ride comfort or gas milage using same motor? My father and I are at arms over it. I don't believe there will be a large difference and he disagrees. He believes it will be an uncomfortable ride and bad/worse gas milage. Any info would be appreciated.
ATMINF Posted February 11, 2008 Posted February 11, 2008 I currently have a 2500HD and have rode in 3500 duallys and SRW and there was not alot of difference that I could tell. They also seemed to have about the same gas(SRW) mileage. But I also think that my 2500HD does NOT ride rough, a little stiff but not bad at all. But thats my 2 cents!
s-ten Posted February 11, 2008 Posted February 11, 2008 There won't be much difference in ride or mileage, the 3500HD is basically the same as the 2500HD but with more payload capacity. If you are going to go with a long bed anyway, might as well get the 3500HD. My dad has an '05 Dually, and I think it rides better then a shorter wheelbase 2500HD that a friend owns. Because there is only 250 lbs difference between the two the mileage should be the same.
wellinghurst Posted February 11, 2008 Posted February 11, 2008 My dads 1999 3500 RCLB rides horrible compared to a 2500. Running over a penny feels like a speed bump. I am sure it gets better with heavy loads, but empty it's pretty bad.
