Build Sheet For My Truck
Hi fellow truckers,
If someone could pull the build sheet for 2GTEC19V631280050, it'd be really appreciated.
Thanks very much.
VIN : 2GTEC19V631280050
VEHICLE INFORMATION
Merchandising Model : TC15753 -2003 SIERRA SL SHORT BOX 2WD Warranty Start Date : 06/30/2003
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : BOISVERT PONTIAC BUICK LTEE
470, BOUL. CURE-LABELLE
BLAINVILLE , PQ J7C2H2
(450) 430-9400
Selling Source : 14 - GM OF CANADA
Site Code : 86355
Business Associate Code : 120924
Service Contract :
No
Branded Title :
No
Warranty Block :
No
PDI Status :
Paid
REQUIRED FIELD ACTIONS
Type
Number
Description
Posted Date
Status
RC
04007
TAILGATE SUPPORT CABLE ??
N/A
Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description
Effective Date
Effective Odometer
End Date
End Odometer
36/60000 BUMPER TO BUMPER LIMITED WARRANTY
06/30/2003
8 kilometres
06/30/2006
60008 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY
06/30/2003
8 kilometres
06/30/2009
160008 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM
06/30/2003
8 kilometres
06/30/2011
130008 kilometres
36/60000 FEDERAL EMISSION
06/30/2003
8 kilometres
06/30/2006
60008 kilometres
CLAIM HISTORY
R.O Date
R.O Number
Type
Labor Operation
Odometer Reading
04/11/2006
321349
V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 63641 kilometres
10/07/2004
278060
B5750 - SUPPORT, TAILGATE/ENDGATE CABLE - ONE OR BOTH - REPLACE 34320 kilometres
12/08/2003
253708
B9654 - LAMP ASSEMBLY, EXTERIOR - LICENSE (ONE OR BOTH) - REPLACE 10325 kilometres
02/03/2003
A80050
I
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
? 1998-2005 General Motors Corporation. All Rights Reserved.
CLAIM HISTORY
Repair Order Date : 04/11/2006 Repair Order Number : 321349 Odometer Reading : 63641 kilometres
Serviced By : BOISVERT PONTIAC BUICK LTEE
BLAINVILLE, PQ J7C2H2
(450) 430-9400 Selling Source : 14 - GM OF CANADA
Site Code : 86355
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
04/14/2006 682 01 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980509 N
Repair Order Date : 10/07/2004 Repair Order Number : 278060 Odometer Reading : 34320 kilometres
Site Code : 86355
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
10/12/2004 525 01 # B5750 - SUPPORT, TAILGATE/ENDGATE CABLE - ONE OR BOTH - REPLACE 88980509 N
Repair Order Date : 12/08/2003 Repair Order Number : 253708 Odometer Reading : 10325 kilometres
Site Code : 86355
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
12/12/2003 438 01 # B9654 - LAMP ASSEMBLY, EXTERIOR - LICENSE (ONE OR BOTH) - REPLACE 15082619 N
Repair Order Date : 02/03/2003 Repair Order Number : A80050 Odometer Reading : 0 kilometres
Site Code : 86355
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
02/07/2003 350 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
VIN 2GTEC19V631280050
VEHICLE BUILD
Gross Vehicle Weight Rating : 2815 kg (6207 lb) Order Number : N71134
Build Date : 02/03/2003 Build Plant : 23153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - 40/20/40 FRONT SPLIT BENCH SEAT AL0
AM7 - 60/40 SPLIT FOLDING REAR SEAT B30 - FLOOR CARPETING
B32 - FRONT AND REAR FLOOR MATS B33 - REAR FLOOR MATS
B85 - BODY SIDE MOULDINGS CJ3 - AIR CONDITIONING, DUAL ZONE
DE2 EVA
E63 - FLEETSIDE BODY OPTION FE9 - FEDERAL CERTIFICATION EMISSION
GU6 - 3.42 REAR AXLE RATIO G80 - AXLE - LOCKING DIFFERENTIAL
JC3 KUP - ENGINE PTO CONTROL VARIABLE SPEED
K05 - HEATER - ENGINE BLOCK K68 - 105 AMP DELCOTRON GENERATOR
LR4 - VORTEC 4800 SFI V8 ENGINE M30 - 4-SP ELECTRONIC AUTO/OVERDRIVE
NF2 - FEDERAL EMISSION SYSTEM OSG
PY2 - 16" CHROME WHEELS (4) P03 - CHROMED WHEEL CENTRE CAPS
QNF - TIRES - P235/75R-16" AS BW Q4B - GVWR: 2812 KG (6200 LB)
R6Z R7K - MISSING OPTION CREDIT
R9Z SAF - SPARE TIRE LOCK
SLM UM7 - RADIO - AM/FM STEREO
UQ5 U19 - KILO SPEEDOMETER
VB3 - CHROME REAR STEP BUMPER VG3 - CHROME FRONT BUMPER
VK3 - LICENSE PLATE BRACKET VXS
V22 - FRONT GRILLE W/ CHROME SURROUND V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - FRONT TOW HOOKS (2) XNF
YD3 YD6 - REAR SPRING BASE EQUIPMENT
YK6 - SEO IDENTIFICATION YNF
ZE5 - SIERRA SL MODEL ZNF
ZY1 - SOLID PAINT Z31 - PRELIMINARY INVOICE
Z49 - CANADIAN BASE EQUIPMENT Z83 - STANDARD SUSPENSION
Z88 1SB - PREFERRED EQUIPMENT GROUP
11U - PEWTER METALLIC 52C - NEUTRAL
52I - GRAY 6MT
7MT 9X5 - CUSTOM CLOTH SEAT TRIM
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : FBD Traceability : 030311148
Date Scanned : 02/01/2003 Time Scanned : 10.42.00 Scan Station : 04
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : WKU Traceability : 241710293
Date Scanned : 02/01/2003 Time Scanned : 08.38.00 Scan Station : 10
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : DSX Traceability : DSX
Date Scanned : N/A Time Scanned : N/A Scan Station : N/A
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 04
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 3CJD Traceability : 35348122
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 05
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : WW5 Traceability : 008950
Date Scanned : 02/01/2003 Time Scanned : 11.15.00 Scan Station : 07
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YCTJ Traceability : 23027U8PH
Date Scanned : 02/01/2003 Time Scanned : 15.27.00 Scan Station : 05
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 8115 Traceability : 130254KM1
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 6170 Traceability : 00172958
Date Scanned : 02/01/2003 Time Scanned : 11.12.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 5378 Traceability : 9DHW52C
Date Scanned : 02/01/2003 Time Scanned : 13.13.00 Scan Station : 11
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : V - DELCO ELECTRONICS REYNOSA MEXICO
Part/Num Broadcast : 7506 Traceability : 3008HMQNR
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 7506 Traceability : 3009HMR5Q
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 2350 Traceability : 8XAMI36
Date Scanned : 02/01/2003 Time Scanned : 08.38.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2446 Traceability : 130239LSC
Component Code : BX
Source Plant : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 06
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 1490288
Date Scanned : 01/27/2003 Time Scanned : 23.02.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 4179881
Date Scanned : 02/01/2003 Time Scanned : 08.10.00 Scan Station : N/A
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 06/30/2003 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 8 kilometres
(450) 430-9400
Delivery Selling Source : 14 - GM OF CANADA
Delivery Site Code : 86355
End Odometer
06/30/2003
8 kilometres
06/30/2006
60008 kilometres
06/30/2003
8 kilometres
06/30/2009
160008 kilometres
06/30/2003
8 kilometres
06/30/2011
130008 kilometres
06/30/2003
8 kilometres
06/30/2006
60008 kilometres
CLAIM HISTORY
Thanks very much!
What does the bold/italic part mean though ? 160,000km, that's 100,000 miles. And in 2009 ? What?
Truck has been sold to me with only 60k miles on. I thought it made sense and Carfax and the DMV here too thought so.
