Laptop In Truck?
Mikeee
I'm looking at getting a mount for my laptop.
Any thoughts out there?
You gotta be serious and willing to drill some holes........ Try This! They have a couple other options, but I want my laptop SECURE!
There are some bolt-on solutions, such as the Ram-mount. But most I found would end up taking up too much passenger leg room or just wouldn't work in my vehicle. There was also some discussion here as well. Haven't seen and pics here of them installed from anybody around here though, so it's sorta hard to say.
I'm not sure what business your in but the Panasonic toughbook (CF-18 or 19) is worth a look. Option to order a locking base plate. Plus the laptop itself is not so bulky.
My old set up in my 99 Savanna
I like the one Big Red suggested too above, from Laptop travel
I'll have to consider the custom work top. Mine will go in my '03 Savana.
Only problem is Mikeee you'll need to drill some cup holders in your desk if ya cover them up (Like I did) A trip in the morning without a coffee is way offside LOL
Looks like you already have spilled coffee in front of the Motorola. :rant:
Well then you get the idea :rant: for drilling the cup holders.
In Canada you can go to the electric chair for spilling "Tim Hortons" coffee...
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
