Anyone know or used brighter backup lights that replace stock bulbs? I know they make the fog light type back up lights but I am just looking for something to replace my factory bulbs. I know you can buy brighter stock bulbs from an autoparts store but I was wondering if they made LED style bulbs that make it VERY easy to see behind you when you put it in reverse. It is a PITA to backup with tinted windows at night using only your mirrors.
Thanks,
I know what you mean at night my back windows are practically solid black. I didn't use LED's but I put PIAA Xtreme white bulbs in and they help a bunch.
what bulb did you use?
I'd love to know too. :puke:
Thats not too bad, i'll consider it. I have a crewcab with tint, & I have smoked tails so its probably hardest for me to see :puke:
i have LEDs for reverse lights. they are extremely bright. it almost hearts to look at them, lol. they have 57 LEDs on one bulb. i got them of ebay. i dont think they cost alot either. check the pics on my site. the pics arent that good but youll get the idea
http://s54.photobucket.com/albums/g105/hea...y29/gmc%202500/
Those look great, but I can't find them on ebay. Anybody know of where I can get these (online or not)?
Just ordered my PIAAs tonight. :flag: The price wasn't really that bad considering how it will keep me from backing over something now that I will be able to see. :) Now I have to wait on UPS :P
Thanks again for the info/link Rocco715
