Cooled Seats
Looking through the fuse box the other day notice i have a fuse for cooled seats
looked under my front seats and found a wireing harness and i clear tube with i guess water running through it...
Anyone knoe how these work?
Did you read the manual? I've never heard of liquid cooled seats before, just perforrated leather with an AC vent hooked up to the seat to blow air through...
no but i was just about to go down and get it
ill post pics of whats under my seat
It may be that the vehicle identifies an occupant by measuring air pressure forced from a bladder inside the seat cushion. This may be the hose that feeds the sensor.
The cooled seats on the Caddy have small perforations with air conditioning running through it. I had the same thing on my Lincoln Navigator.
It feels like your pants are getting wet when you first turn them on.
For the air bags? Very possible. I'm still going to say it's for the lumbar though. Let's solve this mystery! :crackup:
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
