Can I Pull More Then A Tahoe?
What do you mean "pull more"? Pulling comfortably on the highway, putting the two trucks back to back and pulling, pulling out tree stumps?
Also, what are the engines in the two trucks, gearing, 4x4 vs. 2x4, type of tires. You'd best go and test this yourself because I don't know if anyone can answer your question here. My opinion would be that if both trucks have the 5.3 L V8, that it will be close, probably to the point where it would be undistinguishable??
I believe the weights are the same.....engine for same engine. U could do the search on the GM website by just looking up the specs.
They are basically the same vehicle if you really look into the mechanicals. I'd say it would be a tossup.
