'08 Ltz Nav System, No Rear Ent. Play Dvd?
I'm trying to see if my nav system will play DVDs. I don't care about watching while not in park. I have aftermarket DVDs in the rear headrests. When I put a dvd in it says disc error. It says it will play DVD music. would this be a softwear issue? The manual says that the nav can play dvds with the rear entertainment package, so is it a different one? I tried to find some info by doing a search but could not locate a thread. Not sure of the model # on the nav but the code is
"U3URadio, AM/FM Stereo, CD, Nav, Voice Rec."
Hope this helps
thanks in advance
Dan
Hope this helps
thanks in advance
Dan
On the unit itself, does it day DVD anywhere on it? if not, then i dont think it can. i have a stock nav unit in my ext cab ltz and for fun i put a dvd in it and it gave the same error.
It says it will play dvd music...
Does yours have dvd logo?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
