Ven Check
VIN : 1GKEK13T95J107081
VEHICLE INFORMATION
Merchandising Model : TK15706 -2005 YUKON - 4WD Warranty Start Date : 02/25/2005
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : LOTSPEICH MOTORS, INC.
PO BOX 374
WARRENSBURG , MO 64093-0374
(660) 747-9165
Selling Source : 48 - GMC TRUCK
Site Code : 30309
Business Associate Code : 116180
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 02/22/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 87L860M7 XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/25/2005 15 miles 02/25/2008 36015 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/25/2005 15 miles 02/25/2011 100015 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/25/2005 15 miles 02/25/2013 80015 miles
36/36000 FEDERAL EMISSION 02/25/2005 15 miles 02/25/2008 36015 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/09/2007 057245 0 F2122 - CARRIER ASSEMBLY - FRONT DIFFERENTIAL - R&R 40639 miles
10/11/2006 017691 # B7866 - MOLDING, FRONT DOOR - RIGHT - SIDE - R&R OR REPLACE 33651 miles
08/29/2006 016658 # B7876 - MOLDING, FRONT DOOR - LEFT - SIDE - R&R OR REPLACE 28480 miles
06/30/2006 015066 # B7876 - MOLDING, FRONT DOOR - LEFT - SIDE - R&R OR REPLACE 25247 miles
11/28/2005 009840 # B7866 - MOLDING, FRONT DOOR - RIGHT - SIDE - R&R OR REPLACE 15790 miles
11/28/2005 009840 # B7876 - MOLDING, FRONT DOOR - LEFT - SIDE - R&R OR REPLACE 15790 miles
09/30/2005 008430 # L1020 - CAP, FUEL TANK - REPLACE 12013 miles
08/09/2004 A07081 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
CLAIM HISTORY
Repair Order Date : 03/09/2007 Repair Order Number : 057245 Odometer Reading : 40639 miles
Serviced By : ALBERT BUICK-HONDA-GMC
1717 N PROVIDENCE RD
COLUMBIA, MO 65202-1590
(573) 442-3107 Selling Source : 48 - GMC TRUCK
Site Code : 30340
Business Associate Code : 118340
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
03/13/2007 777 01 0 F2122 - CARRIER ASSEMBLY - FRONT DIFFERENTIAL - R&R 09413427 - BRG ASM-R N
Repair Order Date : 10/11/2006 Repair Order Number : 017691 Odometer Reading : 33651 miles
Serviced By : LOTSPEICH MOTORS, INC.
PO BOX 374
WARRENSBURG, MO 64093-0374
(660) 747-9165 Selling Source : 48 - GMC TRUCK
Site Code : 30309
10/20/2006 736 01 # B7866 - MOLDING, FRONT DOOR - RIGHT - SIDE - R&R OR REPLACE 15176375 - MOLDING Y
Repair Order Date : 08/29/2006 Repair Order Number : 016658 Odometer Reading : 28480 miles
PO BOX 374
Site Code : 30309
09/15/2006 726 01 # B7876 - MOLDING, FRONT DOOR - LEFT - SIDE - R&R OR REPLACE 15176374 - MOLDING Y
Repair Order Date : 06/30/2006 Repair Order Number : 015066 Odometer Reading : 25247 miles
PO BOX 374
Site Code : 30309
07/28/2006 712 01 # B7876 - MOLDING, FRONT DOOR - LEFT - SIDE - R&R OR REPLACE 15176374 - MOLDING Y
Repair Order Date : 11/28/2005 Repair Order Number : 009840 Odometer Reading : 15790 miles
PO BOX 374
Site Code : 30309
12/06/2005 645 01 # B7866 - MOLDING, FRONT DOOR - RIGHT - SIDE - R&R OR REPLACE N/A Y
12/06/2005 645 02 # B7876 - MOLDING, FRONT DOOR - LEFT - SIDE - R&R OR REPLACE N/A Y
Repair Order Date : 09/30/2005 Repair Order Number : 008430 Odometer Reading : 12013 miles
PO BOX 374
Site Code : 30309
10/07/2005 628 01 # L1020 - CAP, FUEL TANK - REPLACE N/A Y
Repair Order Date : 08/09/2004 Repair Order Number : A07081 Odometer Reading : 0 miles
PO BOX 374
Site Code : 30309
08/13/2004 508 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
VIN 1GKEK13T95J107081
VEHICLE BUILD
Gross Vehicle Weight Rating : 3133 kg (6908 lb) Order Number : HJQQ7Q
Build Date : 08/09/2004 Build Plant : 15J06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - POWER DRIVER SEAT ADJUSTER AG2 - POWER FRONT SEAT ADJUSTERS
AJ1 - DEEP TINTED GLASS AJ7 - DRIVER/PASS FRT & SIDE AIR BAGS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT AL4 - SECOND ROW CAPTAIN'S CHAIRS
AN3 - BUCKET SEATS W/FRT LTHR SEATING SURFACES, DR/FRT PASS 10-WAY PWR ADJ, HEATED SEATS W/PWR LUMBAR, 2-POS DR SIDE MEMORY AP9 - CONVENIENCE NET
AS3 - THIRD ROW 50/50 SPLIT BENCH SEAT AU0 - REMOTE KEYLESS ENTRY SYSTEM
AXP - MPV VIN IDENTIFICATION A31 - POWER WINDOWS
BVE - ASSIST STEPS B30 - COLORED - KEYED CARPETING
B58 - FRT & CTR CARPETED FLOOR MATS B85 - BODY SIDE MOLDING W/BRIGHT INSERT
CF5 - POWER SUNROOF HOMELINK UNIVERSAL TRANSMITTER CJ2 - DUAL ZONE AUTOMATIC AIR CONDITIONING
C25 - REAR WINDOW WASHER/WIPER C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER C5H - GVW RATING - 6,900 LBS
C69 - REAR AIR CONDITIONING DF5 - LT SENSITIVE INT R/V MIRROR W/OUTSIDE TEMP & COMPASS
DH6 - ILLUM LH & RH VISOR MIRRORS DK8 - DELUXE OVERHEAD CONSOLE
DL3 - OSRV PWR HTD, FOLDING MIRRORS TURN SIGNAL, CURB-TILT DT4 - SMOKER'S PACKAGE
D07 - FLOOR CONSOLE EVA - EVAP EMISSION REQUIREMENT
E52 - LIFTGATE W/LIFTGLASS FE9 - 50-STATE EMISSIONS
FK2 - TORSION BAR SPRING ADJ - LH FK3 - TORSION BAR SPRING ADJ - RH
GU6 - REAR AXLE - 3.42 RATIO G69 - LEVEL CONTROL AUTO, AIR, HD
G80 - LOCKING REAR DIFFERENTIAL JAN - ASSEMBLY PLANT-JANESVILLE, WI
JF4 - POWER ADJUSTABLE PEDALS JH2 - BRAKE HYD POWER, DISC
JL4 - STABILITRAK KNP - H.D. TRANSMISSION OIL COOLER
KUP - THROTTLE CONTROL ELECTRONIC KW1 - ALTERNATOR 160 AMP
K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER
LM7 - VORTEC 5.3L V8 SFI GAS ENGINE M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NP5 - LEATHER WRAPPED STEERING WHL NR4 - TWO SPEED TRANSFER CASE
NT8 - FEDERAL EMISSION SYSTEM PCR - SUN, SOUND AND ENTERTAINMENT INCLUDES: *REAR SEAT ENTERTAINMENT SYSTEM *POWER SUNROOF
PDC PDY - SAFE AND SECURE INCLUDES: *SIDE IMPACT AIR BAGS *AUTORIDE SUSPENSION
P27 - 17" PREMIUM ALUMINUM WHEELS QAS - P265/70R17 ALS WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE R6J - CUSTOMER DIALOGUE NETWORK
R9G - JL4 AS STANDARD R9U - GM ACCESS-AUTOBOOK IDENTIFIER
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS T96 - FRONT FOG LAMPS
UC6 - AM/FM STEREO W/6-DISC CD CHANGER (REPLACES STD/OPT RADIO) UE1 - ONSTAR SYSTEM INCLUDES 1 YEAR SAFE & SOUND
UG1 - HOMELINK UNIVERSAL TRANSMITTER UJ6 - TIRE PRESSURE MONITOR
UK3 - STEERING WHEEL RADIO CONTROLS UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE PREMIUM 9 SPEAKER SYSTEM U2K - XM SATELLITE RADIO-OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA.1ST 3MOS.INCL
U42 - REAR SEAT ENTERTAINMENT SYSTEM VB3 - CHROME REAR BUMPER
VFF - VIDEO FORMAT REGION 1 NTSC VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL
V1K - LUGGAGE CARRIER CROSS RAILS V22 - CHROME GRILLE SURROUND
V54 - ROOF MOUNTED LUGGAGE CARRIER V73 - STATEMENT OF CERT. U.S.
V76 - RECOVERY HOOKS XAS - P265/70R17-113S WOL TIRE
YAS - P265/70R17 ALS WOL YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR
ZMJ - P265/70R15 ALS BW TIRE-SPARE ZM9 - HOMELINK UNIVERSAL TRANSMITTER
ZY1 - SOLID PAINT Z55 - AUTORIDE
Z82 - HEAVY DUTY TRAILERING EQUIP. Z88 - GMC TRUCK NAMEPLATE
1SD - SLT DECOR INCLUDES: *FRONT LEATHER SEATING SURFACES *ASSIST STEPS *FULL FUNCTION FRT BUCKET SEATS *BOSE PREMIUM 9 SPEAKER SYSTEM *REAR SEAT AUDIO CONTROLS *POWER ADJUSTABLE PEDALS *CARGO NET *LUGGAGE CARRIER CROSS RAILS *THIRD ROW 50/50 SPLIT SEAT *IN DASH 6 CD PLAYER (REPLACES STD/OPT RADIO) *XM SATELLITE RADIO-OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA.1ST 3MOS.INCL *ONSTAR SYSTEM INCLUDES 1 YEAR SAFE & SOUND *STEERING WHEEL CONTROLS *HOMELINK UNIVERSAL TRANSMITTER *POWER FOLDING OSRV MIRROR *ELECTROCHROMIC ISRV MIRROR WITH TEMPERATURE & COMPASS 1SZ - PREF EQUIP DISCOUNT
15U - SAND BEIGE METALLIC 52I - NEUTRAL INTERIOR TRIM
522 - NEUTRAL/SHALE 6XK - COMP FRT LH COMPUTER SEL SUSP
7XK - COMPONENT FRT RH COMP. SEL SUSP
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : WCJ Traceability : 042015065
Date Scanned : 08/09/2004 Time Scanned : 15.43.00 Scan Station : 01
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : U2K Traceability : 240712164
Date Scanned : 08/09/2004 Time Scanned : 15.33.00 Scan Station : 01
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : C
Part/Num Broadcast : CL Traceability : 021684
Date Scanned : 08/09/2004 Time Scanned : 16.41.00 Scan Station : 01
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 5KCD Traceability : 39885632
Date Scanned : 08/09/2004 Time Scanned : 15.50.00 Scan Station : 01
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : WX8 Traceability : N011205
Date Scanned : 08/09/2004 Time Scanned : 16.53.00 Scan Station : 01
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : BFA Traceability : 000894
Date Scanned : 08/09/2004 Time Scanned : 16.51.00 Scan Station : 01
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YHZS Traceability : 0421118N6
Date Scanned : 08/09/2004 Time Scanned : 20.08.00 Scan Station : 01
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 6225 Traceability : 24213U0AB
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 4233 Traceability : 00017088
Date Scanned : 08/09/2004 Time Scanned : 17.11.00 Scan Station : 01
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 8216 Traceability : 1EYMB2U
Date Scanned : 08/09/2004 Time Scanned : 16.10.00 Scan Station : 01
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 3522 Traceability : 421000AYT
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 3522 Traceability : 421000AYU
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 9601 Traceability : 9YAHH06
Date Scanned : 08/09/2004 Time Scanned : 15.19.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2622 Traceability : 14215GT8B
Component Code : AT - RIGHT SIDE IMPACT SENSING MODULE
Part/Num Broadcast : 3521 Traceability : 4204A04EZ
Component Code : AU - LEFT SIDE IMPACT SENSING MODULE
Part/Num Broadcast : 3521 Traceability : 4204A090E
Component Code : BO
Source Plant : X
Part/Num Broadcast : 7591 Traceability : 041870K85
Component Code : BP
Source Plant : X
Part/Num Broadcast : 5142 Traceability : 041830DE1
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0120976
Date Scanned : 08/03/2004 Time Scanned : 04.08.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1WW Traceability : 1067454
Date Scanned : 08/04/2004 Time Scanned : 09.24.00 Scan Station : N/A
Component Code : CG - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1PP Traceability : 1065292
Date Scanned : 08/06/2004 Time Scanned : 01.28.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1GG Traceability : 1062574
Date Scanned : 08/09/2004 Time Scanned : 12.48.00 Scan Station : N/A
Component Code : ZU
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : 87L860M7
Component Code : ZV
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : 142131467
Component Code : ZX
Source Plant : 4
Part/Num Broadcast : 0014 Traceability : 40228
Component Code : ZY
Source Plant : 0
Part/Num Broadcast : 0510 Traceability : 477416
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 02/25/2005 Delivery Type : 021 - GMO EMPLOYEE OUT-OF-STOCK/OPTION 2 Delivered Odometer : 15 miles
PO BOX 374
(660) 747-9165
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 30309
INVOICE INFORMATION
Invoice Date : 01/07/2005
Site Address : LOTSPEICH MOTORS, INC.
PO BOX 374
Site Code : 30309
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 374
Site Code : 30309
SERVICE CONTRACT
Policy Number : 816402183 Owner Name : XXXXXXXXXXXXX
Description : 24/24000 GMPP MAJOR GUARD
Deductible Amount : $ 50
Inception Date : 01/23/2007 Expiration Date : 10/10/2007
Inception Odometer : 37102 miles Expiration Odometer : 48155 miles
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,165 Guests (See full list)
