Excessive Oil Consumption
donmattson
I own a 1995 C1500 Chev WT with a 4.3 engine. It has 254K miles and I drove 93K in 2007 escorting oversize loads. Other than high miles, the engine runs well.
For about six months, I was losing coolant at the rate of a gallon every month or so. Two weeks ago, I had a mechanic perform a pressure test. He recommended replacing the intake manifold gasket. The gasket replacement fixed my coolant leak but I used about 3.5 quarts of oil in the last 500 miles!
I returned the truck to the mechanic. He could not find visible leaks on the bottom of the engine. He put dye into the oil but the tailpipe showed clean of the dye.
Spark plugs were new about 5K miles ago; wires are about 10K old. Engine idles well and begins to almost to misfire at 55-60 mph. The computer, I assume, keeps the engine running well.
The mechanic said the surface of the intake manifold was smooth and clean when he reinstalled it. He could not see or feel any heat damage. He replaced two other gaskets this past week with no problems such as mine.
Other than piston rings going south on me in the time after intake manifold gasket replacement, I cannot come up with anything else that would cause such high usage.
All that antifreeze might have caused cylinder scuffing. But that much should show on the plugs if its burning it. Make sure it's not getting in the coolant. Mark.
Since posting this situation, I drove about 3000 miles. I have added about a quart per thousand miles. The mechanic changed the oil and used 20W/50; I have been using 5W/30 and the garage thought it was too thin. The major change I see is a bit higher oil pressure. However, the oil seems like I am pouring honey or molasses! Oil consumption decreased from a quart per hundred miles when I first posted. I assume the mechanic and garage is trying to "seat" the intake manifold gasket.
Gas mileage remains average and performance is good. I don't see clouds of black smoke out of the exhaust. No oil is on my garage floor.
Yep, I'd say the running 5W/30 is waaaaaay to thin for 254,000+ miles.
I have 345,000 on my 4.3 and I add a quart of 20W/50 every 180 miles. I don't need to do "oil changes" anymore.
Add oil ... check the gas :crackup:
I have had a set of intake gaskets go south and burn oil. You could not tell by looking at the tail pipe and it did misfire. The plug for the hole that was misfiring had an excessive build up on it. Turns out that portion of the intake gasket was leaking internal to the engine on the runner. I sprayed a little brake cleaner into the crankcase and the engine stumbled.
You wrote that a "portion of the intake gasket was leaking internal to the engine" – did that mean a portion of the gasket failed over that cylinder or that it shifted when the intake manifold was reinstalled? Did you install a new gasket? Have you fixed the problem?
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
