Bulild Gm Factory Id...
No,But if you give me the VIN I might be able to run it (depending what year it is) and tell you where it was built.
Vin: ( it is a 1998 )
1GBMP37B2W3311219
Thanks...
Here ya' go....It was built at GM's Detroit,MI. plant (When was the last time time a vehicle was built in Detroit?!?!? :crackup: )
It also has an open recall.....
GM Vehicle Inquiry System
Summary
VIN : 1GBMP37B2W3311219
VEHICLE INFORMATION
Merchandising Model : CP32012 -1998 HD MOTOR HOME CHASSIS - 208"
Warranty Start Date : 03/17/1999
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MC CORMICK MOTORS, INC.
1255 W MARKET
NAPPANEE , IN 46550-1798
(574) 773-3134
Selling Source : 13 - CHEVROLET
Site Code : 11337
Business Associate Code : 113414
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 98060 CALIBRATION REFLASH N/A Open
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/17/1999 2559 miles 03/17/2002 38559 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/17/1999 2559 miles 03/17/2005 102559 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/17/1999 2559 miles 03/17/2007 82559 miles
36/36000 FEDERAL EMISSION 03/17/1999 2559 miles 03/17/2002 38559 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/25/1999 168361 # N2530 - SWITCH - TURN SIGNAL AND HAZARD WARNING - REPLACE 2566 miles
10/26/1998 448561 # J5350 - PEDAL, ACCELERATOR - REPLACE 1898 miles
10/26/1998 448561 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 1898 miles
10/25/1998 88064F # Z8011 - ROADSIDE SERVICE (TOWING) 1700 miles
10/12/1998 128261 # N6278 - EFI WIRING REPAIR 152 miles
10/09/1998 879BBF # T2020 - TOWING 500 miles
03/17/1998 015819 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 1 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 03/25/1999 Repair Order Number : 168361 Odometer Reading : 2566 miles
Serviced By : FISHER CHEVROLET, INC.
3201 CHEVY LANE
YUMA, AZ 85365-4203
(928) 726-5500 Selling Source : 13 - CHEVROLET
Site Code : 39276
Business Associate Code : 161718
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
04/05/1999 947 01 # N2530 - SWITCH - TURN SIGNAL AND HAZARD WARNING - REPLACE 26054727 N
Repair Order Date : 10/26/1998 Repair Order Number : 448561 Odometer Reading : 1898 miles
Serviced By : CHAPMAN CHEVROLET, L.L.C.
1717 E BASELINE RD
TEMPE, AZ 85283-1452
(480) 838-1234 Selling Source : 13 - CHEVROLET
Site Code : 39064
Business Associate Code : 114652
11/19/1998 908 01 # J5350 - PEDAL, ACCELERATOR - REPLACE 15018481
11/19/1998 908 02 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT
Repair Order Date : 10/25/1998 Repair Order Number : 88064F Odometer Reading : 1700 miles
Serviced By : GM ROADSIDE ASSISTANCE
PO BOX 50098
PHOENIX, AZ 85076-0098
Site Code : 00690
Business Associate Code : 160087
04/15/1999 950 01 # Z8011 - ROADSIDE SERVICE (TOWING)
Repair Order Date : 10/12/1998 Repair Order Number : 128261 Odometer Reading : 152 miles
Serviced By : ERIKS CHEVROLET, INC.
PO BOX 2169
KOKOMO, IN 46904-2169
(765) 457-8333 Selling Source : 13 - CHEVROLET
Site Code : 25162
Business Associate Code : 112925
10/19/1998 899 01 # N6278 - EFI WIRING REPAIR
Repair Order Date : 10/09/1998 Repair Order Number : 879BBF Odometer Reading : 500 miles
PO BOX 50098
Site Code : 00690
10/15/1998 898 01 # T2020 - TOWING
Repair Order Date : 03/17/1998 Repair Order Number : 015819 Odometer Reading : 1 miles
Serviced By : MC CORMICK MOTORS, INC.
1255 W MARKET
NAPPANEE, IN 46550-1798
(574) 773-3134 Selling Source : 13 - CHEVROLET
Site Code : 11337
03/26/1998 840 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Vehicle Build
VIN 1GBMP37B2W3311219
VEHICLE BUILD
Gross Vehicle Weight Rating : 9534 kg (21022 lb)
Order Number : 520CSV
Build Date : 03/06/1998
Build Plant : 1W312
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
CD4 - INTER. W/S WIPER SYSTEM
C7V - GVW RATING - 21000 LB
DET - ASSEMBLY PLANT-DETROIT,MICHIGAN
EK3 - COMPLETE-SHIPPED LOOSE PARTS
ENV - AIR CONDITIONING PROVISIONS
FE9 - FEDERAL/NY/MA/CT EMISSIONS
FL1 - FRONT AXLE - 8100 LB
F10 - I-BEAM FRONT SUSPENSION-7500 LB
GL8 - REAR AXLE - 13500 LB
GQ5 - REAR SUSPENSION - 13500 LB
JF9 - HYD POWER 4-WHEEL DISC BRAKES
J71 - POWER OPERATED PARKING BRAKE
KC4 - ENGINE OIL COOLING SYSTEM
KG3 - 145 AMP GENERATOR
K34 - ELECTRONIC SPEED CONTROL
L21 - VORTEC 7400 V8 SFI ENGINE
MT9 - ALLISON AT542 TRANSMISSION
NA9 - EVAP. EMISSION CONTROL SYSTEM
NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NG5 - 50-STATE EMISSION CERT. REG.
NJ9 - 75 GALLON CAPACITY FUEL TANK
R6P - ZONE 59 IDENTIFIER
R7Y - MOTOR HOME MANUFACT. INCENTIVE
SLM - STOCK ORDERS
VXT - INCOMPLETE VEHICLE LABEL
V01 - HEAVY DUTY RADIATOR
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XTI - 245/70R19.5/F TIRES-FRONT
X88 - CHEVROLET CONVERSION
YTI - 245/70R19.5/F TIRES-REAR
ZTI - 245/70R19.5/F TIRE-SPARE
ZW9 - STANDARD BODY OR CHASSIS CAB
004 - REAR AXLE-4.78 RATIO
01U - SPECIAL PAINT
1SA - OPTION PACKAGE 01
84P - GRAY WHEELS
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : T - CPC TONAWANDA, NEW YORK
Part/Num Broadcast : PPN Traceability : 802270230
Date Scanned : 03/06/1998 Time Scanned : 07.12.00 Scan Station : 01
Component Code : 36 - BUFFER ASSEMBLY VEHICLE SPEED SENSOR
Source Plant : R
Part/Num Broadcast : QMN Traceability : 054997
Date Scanned : 03/06/1998 Time Scanned : 08.24.00 Scan Station : 01
Component Code : 61 - TRANSMISSION
Source Plant : 3
Part/Num Broadcast : RUS Traceability : 210910082
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 01
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : N/A
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : M - DELCO ELECTRONICS MILWAUKEE, WISCONSIN
Part/Num Broadcast : CLAX Traceability : 080551PNT
Date Scanned : 03/09/1998 Time Scanned : 07.23.00 Scan Station : 01
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0280288
Date Scanned : 02/13/1998 Time Scanned : 21.33.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1WW Traceability : 9812522
Date Scanned : 02/17/1998 Time Scanned : 15.18.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 09/18/1998
Delivery Type : 018 - BUSINESS/ORGANIZATION
Delivered Odometer : 10 miles
1255 W MARKET
(574) 773-3134
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 11337
Dealer Information
INVOICE INFORMATION
Invoice Date : 09/15/1998
Site Address : MCCORMICK MOTORS / R-VISION
1255 W MARKET ST
Site Code : 11344
SHIP-TO INFORMATION
Ship-To Date : 03/13/1998
Site Address : NEWMAR CORPORATION
PO BOX 30
NAPPANEE , IN 46550-0030
(574) 773-8891 Selling Source : 13 - CHEVROLET
Site Code : 59578
Business Associate Code : 132233
