Yet Another Header Question
ok...i know that this question is all over this forum...im looking into headers for my truck....2001 Silverado 1500 5.3L 2WD...after reading 10-15 of the already posted topics, i have decided on these:
Thorley Headers 310Y-DA
now, the question i have is, what is A.I.R. injection? and i see nothing on this page about these having the EGR connection. I believe my truck has the EGR, but not the AIR...so please fellas, help with your header knowledge just one more time... :cool:
a buddy of mine has those on his 98 454 they a nice, they turn blue and brown right away just so you know! full length is the best way to go!!
