Torsion Bar Weak?
Hi!,new here but not to gm products.I could not find an answer in a search so here goes.`01 suburban 2500 w/8.1. Front of truck was lower on DS. than pass. Turned up the torsion bar on DS and got the truck back to level R/L.I have almost no adjustment left on drivers side and have 3/4 of an in. showing on pass.side.Can (and do) torsion bars loose their spring after time?Should I replace?Do they make a heavier bar?I don`t know if the lager motor comes in to play in this scenario.Thanks,Toby
Yes, Torsion bars start to sag over time. You can replace them with a heavier bar or you can get a set of green keys which have a higher index than your stock purple keys and that will give you more lift, even with your sagged bars. Suburban 2500's come with GK bars which have a torque capacity of 8615 ft.lbs. You could go with a GL bar which is standard on the 2500HD and 3500SRW. They have a torque capacity of 8782 ft. lbs. Changing the keys is a cheaper way to go but I think if you're in it for the long haul I would change out your bars, either to another set of GK's or go with the GL's. Read this article (www.offroad-tech.com/tech/tb401/) This will answer a lot of your questions.
It is completely normal for the adjustments on each side to be a little bit off from each other, but 3/4" showing on the bolt sounds like a little much. If you can afford it, I'd suggest replacing the bars, as it'll be a more reliable option. If you just get different keys, you'll have to keep cranking them every time the already worn t-bar sags a little bit.
Thank you for the replies gentlemen.I just went through the web page recommended by Jacqson and wrote done some part #`s and will check prices at the gmpartsdirect site for the GL bars and some new retainers.I`ll use my stock keys for now for I am contemplating a ready lift leveling kit with the shock mts.(auto-ride) which include keys, in the future to put on some 265`s or 285`s in the summer.Thanks again for the info.Toby
Just as a side note. If you ever want to remove or have any questions about your autoride, let me know. I have successfuly removed it from my 02 Sub.
Guest Riggs
i would try to find or get a pair from a accident.
I checked with gmpartsdir. and they run $159 @ so I think I`ll just get a new pair.I`m going to keep this truck until it rots away and want to make it right.I also noticed that the rubber bump stops were cracked and funny looking and will change them out while I`m under there.If and when one one or more of the auto-ride shocks bite the big one,I`ll look you up Jacqson and I`ll have to address that issue then.Those factory shocks are quite pricey and how would you ever know if they were doing the auto-thing?I have to measure the torsion bars because I`m seeing same vehicles ones calling for 52" and 54".I`ll figure it out.Thanks again guy`s ,Toby
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
