Wind Noise
2007 Silverado Classic Extended Cab 4x4.
Recently have had the priviledge/terror of letting the young uns start their :lol: driving practice. Since we have the stereo off, I have just noticed a lot of noise from the windshield when on the highway.
I have been reading and searching and most of the noise issues seem to be due to bug guards. I have not done that one yet.
I did see one recommendation was to use a leaf blower to see if we can pinpoint the area of the noise.
Any other suggestions?
Thanks,
Dave
I had the same issue with my YD. Went for a drive with a service tech and they agreed it was quite loud. So they had somebody locally reseal the windshield and found that a somewhat large piece of stripping below the glass was missing. Once resealed, it was much better. Now I just have the "normal" wind noise. :lol:
Guaranteed it is the windshield side molding. People blame it on bug guards. Not always the case. I have had two that did it. The first (2005 Silvie) I took back to the dealership for the noise. It was doing it before I put the bugshield on, just happen to have it on when I got it there. They said it was the bugshield. I took it off in their shop and made them drive it again. They re-stuck the windshield trim back down with their super re-sticking stuff. Did not help. Still did it with a crosswind. My fix (done it on a 05 silverado, 07 tahoe, and 2 07 sierra's) is to use clear silicone caulk under the trim. What you are hearing is that little strip whacking itself against the glass.
Thanks for the feedback. Will see if I can get the dealer to address, otherwise I will try the silicone myself.
gvbhunt...I'm in Dardenne Prairie, (Ofallon) area just west of St. Louis.
I did run into the noise problem with my 06 Silverado but a lot of the problem was caused by the bug shield. It sounded like sand hitting the windshield all the time but it was the rubber molding flapping. Took the bug shield off the those sounds ceased.
