Digital Climate Control
I have a 06 silverado 2500HD and was thinking about installing a digital climate control, what do I need to know? Is there anyting that can prevent me from installing?
Can't be done. Controllers, ductwork, electronics, BCM are all different. The digital climate control isn't that great anyway - I'd rather have the manual system in mine.
I was working this project and decided to quit. Installing all of the sensors is easy. Wiring it up isn't too difficult. However, the auto system has two temperature actuators, they control the flow of air through the ducts. The manual system only has one. And you can't install a second one unless you completely tear out the dash and the duct work. I got all the way to that point and quit.
It's a pain in the ass.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
