T-case Leak
LtE-36
The lower mount bolt on my encoder motor, is leaking fluid from it. I removed it and the threads are still ok but a little trashed. This is the bolt closest to the drain plug. I pulled it out and cleaned it but it still leaks after a couple of days. Any ideas on how to fix or might this be the start of a bigger problem, I swabbed out the hole with a q-tip and got red fluid on the q-tip so I think its leaking from the base of the threads almost like it is cracked internally on that thread, can this be fixed or do I live with it?
Thanks
Jim
03 HD 6.0 gasser
Thanks
Jim
03 HD 6.0 gasser
What if ya try some Permatex on the bolt to seal it?
Thanks
Jim
03 HD 6.0 gasser
Thats what I am gonna try this weekend, Hopefully it works.
Thanks
