Blue Smoke Duriing Start Up.
tmicklet
Hello,
I have a 2004 GMC crewcab with the 5.3L and 87000Kms( mostly highway). Recently (last two weeks) I began to noticed blue smoke when I started the truck. It always smokes during a cold start, sometimes a couple of hours after driving it will smoke on a re-start. The truck has had all regular maintenance and oil changes. I have installed a magnaflow exhaust and volant cai.
The PCV in not serviceale in my truck, apparently its built into the valve cover. I was able to determine that air is flowing through the pcv tube. It is not blocked.
My next guess is the valve guides/seals, but this seems unlikely due to the time frame and mileage. That and I have never heard of a 5.3 having this problem. I have cold started the truck and then shut it off quickly and pulled all the spark plugs and found them all to be wet with oil. Not soaked but not a nice white/brown colour either.
Could anyone suggest another possible cause and/or personal experience with a problem like this?? What could be allowing oil into all cylinders and can fail quickly? Is there something in the intake that can possible cause this? I am thinking something common to all cylinders? I just cant see all the seals wearing at the same time. Any info or suggestions are welcome, thank you for your time.
We've got a 2003 Silverado with the 5.3L that smokes when cranked up cold after sitting facing up hill. Been doing this for approx. 35,000 Miles (truck has 115,000 miles on it now). It burns about 3-4 quarts per 3,000 mile oil change.
Does it seem to do it worse when parked up hill, like on ours? The truck is usually backed into our driveway, which has it facing slightly down hill, so it's not really noticeable most mornings.
i work in a head shop and id honestly say the valve stem seals worn prolly, could be bagged out guides as well though. hard to tell without tearing apart lol
I would have to go with the majority on this, valve guides/seals.
It would be a one in a million, but your truck's heads could of slipped past quality control.
Have you ever noticed tappet noise?
One of the keys that lock the valve stem, may have broke/slipped allowing enough movement to let the oil slide by.
But like, jefferias said, hard to tell without tearing apart.
Hey thanks everyone for your input.
I appreciate the quick response. I have not noticed any valvetrain noise as of yet. Could you explain what you said about the keys that lock the valve stem? Is there a drawing somewhere of these parts? Any info regarding your theory regarding the keys would be appreciated. It may help me determine my next step.
Regarding the other post I also park the truck facing downhill but I notice the smoke either way. If you find out something please let me know.
Thanks again.
Thanks again.
im pretty confident its not your valve stem keepers. they either work or dont and youd know if you lost one cause the valve would fall into the combustion chamber and wammmm NO GOOD. the keepers just have a groove or set of grooves that fit into the valve grooves and they are held on by spring pressure
Thanks for the info jefferias, I had a blonde momment. I was thinking when the other guy said valve keys that there was some wicked cool technology that I had never heard of. I agree with you though the keepers must be ok because there has not been any large whammmo. Its still running great. Noticed the dex-cool was low the other day, maybe another piece of the puzzle? It is going to the dealership tuesday. Cheers
Just an update,
I took the truck into the dealer, they said valve seals and wanted to rip the heads off to change them. I have since done a few things but mainly changed the oil and replaced it with GM 5w-30. Its been a couple of weeks and the smoking is pretty much all gone. I cant believe it, but knock on wood, no huge plumes of blue smoke. The only thing that I can think of is possible the GM oil has an additive to lubricate and swell the valve seals. In any case what ever it is, its working. Thanks everyone for your input. Cheers
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
