2007+ Silver Birch Mirror Caps
I have painted, Silver Birch upper mirror caps that will fit any Chevy/GMC DL3 or DL8 mirror. One inner tab snapped on the LH cap when I removed them from my mirrors, but this should not matter much. I reinstalled them just to check and the cap is plenty secure. Keep in mind these are used, but they are plenty clean with no major blemishes.
$25 shipped.
$25 shipped.
First Dibs!
PM sent.
Thanks,
Mike
I'm looking for these for my truck... where can I find the factory silver birch mirror caps for my 07 NBS Sierra? Thank you.
Message a guy on this board named "MS3DALE". He knows everything there is to know about part numbers for our trucks and is extremely helpful. Tell him you need the part number for the silver birch mirror caps.
Then, either go to your dealer, or try www.gmpartsdirect.com and search for that part number. GMpartsdirect will have them for approx. $60 and they will be on your doorstep in 1-2 weeks.
-Clay
