Hvac Fan Is Making Noise
The HVAC fan in my truck is making noise. It sounds like the fan is hitting some paper or something, there is also a buzz / hum going on. It gets worse as the setting goes up. Anyone know how to get to the fan? It would be nice if i could fix this myself. Any and all help is appreciated.
Probably leaves through the cowl vent. Not sure on the removal. Post your year/model and someone will chime in.
I must have left the fan on a high setting, 3or 4, last time I drove it because when I started the truck this morning the fan came on making the noises. Could starting the truck with the fan on a high setting cause this condition? It operated fine yesterday. Very quiet.
I don't think that would matter....it's probably leaves or debris just like hubbycap stated. Drop the fan down and check it....ever change your cabin air filters?
Drop that plastic cover down on the passengers side (same as you had to do when you changed your cabin air filters) and it's sitting to the far right. The motor is actually hanging straight down towards the floor if I remember correctly. Take out those screws around it and the entire assembly should drop out of the duct.
so it is the round plastic cover on the far right? Thanks!
That should be it...disconnect the plug and drop it out and see if it's filled up w/ crapola....
I have a similar noise on my 00. Have had it for awhile. Its a high pitched noise. If I cracnk it on 4 or 5 speed for a bit and crank is down to 1-2 it goes away. Its really an annoyance.
If you've got a high pitch noise you're fan motor is most probably the culprit...
I tried to get the fan out but could not figure out how. I took out all the screws I could see and a few I couldn't see and still was unable to get the fan out. The round plastic cover comes out after removing 3 screws. I unplugged the fan (2 plugs) and was able to remove the cover but then I could not see how to proceed. It sounded like such a simple thing to try, drop the fan and clean out the crud. Unfortunately this has not been the case. I need more help. Anyone know how to take out the fan? :thumbs:
Rich,
Looking at my service manual it gives the following instructions: Pull the retaining tab down while turning the blower motor counter clockwise in order to disengage the blower motor from the heater/ventilation module.
Hopefully that will help you get it out.
John
In the winter if I leave the fan on high when I get out for the night, it squeals really loud when I start her up in the morning. I just have to turn it off for a few seconds then crank it back up and it's fine, sometimes have to do it twice...
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
