2008 Electronics Trouble
I have a 2008 GMC Sierra and I am having a few problems with it...... The dome light will not turn off, I have to hit the dome override, the doors don't lock when put into gear (eventhough it is set to do so), the panic alarm goes off for no reason when doors are locked for more than 30 minutes.... I had to disconnect the battery last night at the hotel I was staying at because the panic alarm kept sounding. Anyone ever experience these issues, or is it an isloated incident???????
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
