F/s 2003 Ss 6.0 Engine Covers
I have a set of Engine covers from my SS. I painted the outer pieces Red and the center section is the original Black that was cleared.
Looking for $75.00 for the set shipped.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
