Slp Cai...
I have searched but could not really find any usefull info about SLP's CAI... Does anybody have/use one? I like it's non-flashyness compaired to the GMPP one and that its actually one tube and not sections. Can't beat the price either... :)
So, anyone have any input? :)
Thank ya.
anyone use this system?
if not guess ill be the guinea pig lol.
Yep, if you've seen one CAI, you've seen 'em all. Go for it man! :lol:
Jason,
If you are looking for a closed system, I would suggest you take a look at True Flow. It is not for everyone but it is a really nice system with great quailty, fit and finish.
Yep, if you've seen one CAI, you've seen 'em all. Go for it man! :cheers:
ahahahahahaha
yea i think im just gonna go for it, what the hell... why not.
will deffinetly be replacing the filter with an AEM dryflow at some point.
Well if there is anybody out there that cares, lol... I recieved my SLP intake system today and I must say it fits up pretty darn well and wasn't complicated at all. The hardest part was getting the filter to fit all the way over the tube inside the airbox lol.
Not a bad piece for just under $300 I suppose...
Test drive results to come soon...
well i must say, i wasnt expecting much from a CAI... but this system seems to do decent. truck doesnt hesitate to down shift as much and throttle response went up a little too. now ill just have to keep my foot out of it to see how the MPG goes.
deffinetly made the exhaust note a little deeper and when laying on the pedal, kinda sounds like a muscle car more then a truck.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
