Swapping Out The Muffler And Tip Only
Is it possible to just swap out the muffler and maybe have a tip welded on? ECLB exhausts are few and far between and the only other option is having a muffler shop build a system for me. Well they use crush bend pipes and vortec muffler for the same price as a good system. Plus I dont really want to increase the size of the system. All I want is a little bit more of a deeper lope but keep the stock power curve. A chrome tip would be nice too.
What do you guys think?
The first pic is the day of purchase since then I have added nerf bars, westin bull bar, and BF Goodrich All Terrains.
It is possible and can be had for about $200 bucks all in all. I'm looking at doing the same thing and am just waiting to pull the trigger on a Magnaflow 12259 or Hooker Aero Chamber muffler. I've decided not to go with a tip since I want to stick with side exit and it'd be real obvious it was just a tip welded on. You can buy the muffler online for about 2/3s or 1/2 what a muffler shop will charge and then just pay a good shop 30 or so bucks to weld it in.
swapped out the stock muffler for a magnaflow. 22" long 5"X11" case. It's a little louder than stock when idle, but has a nice growl when you get on it. stock pipes
I did the same - only with a flowmaster muffler. It's got a great growl, and you dont lose too much backpressure.
I'm preparing to do the same - with a super 40. I tow a travel trailer so I'm concerned about torque loss, I'm hoping I won't lose any torque with the new muffler. Should I be concerned if I leave everything else stock?
I have another dumb question - which size inlet/outlet do I need for a 2000 5.3 1500? I measured the pipe and the diameter is 2 5/8" (?!?) Which one do I want?
A lot of the flow is in the pipes, not the muffler. Going with a mandrel bent pipe system provides significant performance improvement (probably at the expense of torque - doesn't bother me since I don't tow). That said, what you say about crush bends is absolutely true. When I bought my truck the previous owner had an exhaust shop put on a flowmaster 1 in and 2 out muffler (probably a 40 based on the sound) with duals out the back. The pipes were so badly mangled in the bends I'm amazed gas even reached the back. I took it off and went to a Flowmaster cat back 3" mandrel bent all stainless single side outlet system. It's actually quieter, and runs much better (but is still rumbly, almost to a fault on the highway). So, if you don't want to go full aftermarket system, I believe the next best thing is what you're talking. The stock pipe has to be better than what most muffler shops will mangle up for you.
I used 3" inlet, 3" outlet.
It slipped right over the stock pipes and welded in nicely.
I'm assuming you have a 5.3? Might not matter - they may all be the same. Thanks for the info!!!
on my 5.3L Burb I did exacty what you describe. Do nothing except cut out the stock muffler and install a SS Magnaflow 3" in 3" out of same length. Also added a SS tip, exiting at the side in the stock location...
works very well, sounds nice and has not affected my torque from what I can tell after my last 500 mile trip pulling my 8000# RV :lol:
Good move - probably the best sound for the money.
I still want that trailer, though... :lol:
i putting on a thrush #17661 next payday single in dual out the side in frt of passenger side tire cost me $35.00 i hope it sounds sweet.
I had Thrush mufflers on my '68 Cougar in '70. Nice sound! Doubt they're the same thing these days...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
