Optimal Tire Pressure For Long Trip
05_2500HD
So I'm leaving on a trip tomorrow for 1300 miles, 2005 2500HD 6.0L 4x4. I have 245/75/16 that say 80psi cold on them. What is the optimal tire pressure for gas mileage, etc ?
Thanks !
Thanks !
80psi? you sure its 80psi cold?
Thanks !
Bridgestone Duravis, Load range E, 80 PSI cold
Optimum pressure is suppose to be whatever the truck has labeled on the door, not the max pressure labeled on your tire. With that said, I would go with about 40 PSI.
Hmm OK...door says 60PSI for the front, 80 PSI for the rear ?
I think I'm gonna go with 55 in the front, 60 in the rear...
40-45 psi will net you good mileage and ride as long as you aren't running loaded.
