Failure Without Codes?
Got a question about my poor gas milage. I have a 99 GMC 2500 with the 6.0L with 105k on the clock. I have recently installed a AFE stage 2 intake, a magnaflow dual 3 inch exhaust and 265/70 R17 tires. I know the 6.0L is not know for good milage, but prior to installing the exhaust I was getting around 14 city and 15 highway. After installing the exhaust the best I have gotten is 12. I would have thought by opening up the exhust I would have seen a slight gain in mileage, but not a decrease. Can O2 sensors be off without throwing any codes? I have also ran a couple of tanks through with injector cleaner hoping that this might help some. I have installed new plugs and wires, but have yet to install a new fuel filter. I am simply looking to get my mileage back to where it was if not a little more.
Any thoguhts on what I could check. I am planning on switching over to snthetic engine oil at my next change, and probably should get the tranny serviced and my switch over to Amsoil. should I look at my injectors? This is my first high mileage fuel injected rig so I am just trying to look at everything. I am looking into a programmer or custom tune for it in the near future, but what might be some things I could look at now to try to get the numbers back up.
Thanks.
These engines need back pressure to operate correctly, the 3" exhaust is your problem. Also if you didnt correct the speedo input for the larger tires your engine & transmission calibrations are off too.
+1 :)
My speedo is about half a tenth off, so its really not as far off as I initially thought it was.
As for the exhaust being too big and not having enough back pressure, I am not gonna have new pipe bend for it. I was thinking what if infront of the muffler Ihad acouple smaller pipes expanded on the ends to fit in line with what I currently have, but would restrict the exhaust a little giving it a little more back pressure......................does that seem like a good route to go?
I like the new power I have gained, this will help out when i start pulling the horse trailer for my wife.
More power = less fuel economy, and less back pressure raises the torque band, you need to keep the engine in the lower of the peak torque band to get best fuel economy.
