Gm Tech Notes On Biodiesel
Traditionally, diesel fuel has been refined from crude oil, and is referred to as petroleum-based (or petro) diesel. It is now possible to manufacture diesel fuel from biological (plant and animal) materials. This fuel is referred to as biodiesel. Biodiesel fuel is blended with petrodiesel fuel (typically 5% bio and 95% petro), and the result is referred to as a blended fuel. Because the characteristics of petroleum diesel and biodiesel fuels are different, questions arise about the use of biodiesel fuels in GM vehicles. Here are some typical questions and answers.
Owner manuals state that GM diesel engines can operate on up to 5% biodiesel fuel. Are all 5% biodiesels the same?
GM currently supports the use of up to 5% blend of biodiesel (B5) in all its diesel vehicles.
GM does not distinguish between the types of feedstocks (different vegetable oils and animal fats) used to make biodiesel. However, biodiesels are not all the same. Biodiesels made from different feedstock will have different cloud points (see below) and subsequently blends made from these feedstocks will have different cloud points. In addition, some variations in cloud point can be expected due to processing differences.
Inconsistent blend compositions might result based on blending methods (example splash blending) and temperature of blending (it is recommended that biodiesel be kept at least 10°F (6° C) above its cloud point during blending). Cloud point will increase with increasing amounts of biodiesel in blends.
Feedstock
Cloud Point
Soy
approx. 32°F (0°C)
Beef-tallow
approx. 53°F (12°C)
When using 5% biodiesel, are there negative performance or durability considerations?
ASTM International (originally known as the American Society for Testing and Materials) is the organization which defines the desired quality of biodiesel for vehicular use in the US.
If the biodiesel meets the ASTM standard, there are no durability concerns at the 5% level. However, if the original biodiesel does not meet the ASTM specification, even with 5% there is potential for negative effects. For example, glycerin is a byproduct formed when vegetable oil is processed to make biodiesel. This is a potential contaminant. In addition, any unreacted vegetable oil is also a potential contaminant. Biodiesels high in glycerin and unreacted vegetable oil content (>0.24 mass %) can result in gelling at higher temperatures, causing filter plugging, and can also cause long term injector damage.
5% biodiesel can cause negative effects if the fuel in the tank deteriorates to form insoluble (plastic-like) constituents and corrosive products.
Biodiesel fuel has a higher tendency to foul and oxidize compared with petroleum diesel fuel. Performance at cold temperatures will be somewhat worse because biodiesel naturally has a higher cloud point than diesel fuel.
Could 5% biodiesel be a cause for premature filter plugging?
Yes, if biodiesel is out of spec for glycerin or when it oxidizes to form polymeric constituents. Biodiesel can act as a solvent, loosening sludge in the bottom of the tank that will cause the filter to plug.
How much does ambient temperature affect biodiesel's ability to flow in a suction-only fuel delivery system?
Ambient temperature affects the fuel's tendency to gel and its ability to flow. As the fuel is cooled, its ability to keep the wax dissolved decreases, and eventually, a temperature is reached when the wax precipitates from the fuel. The temperature when the fuel first becomes cloudy due to wax precipitation is called the cloud point. As the fuel is cooled further, more wax precipitates from the fuel. At about 10°F (6° C) below the cloud point, the fuel becomes so thick that it cannot flow. This temperature is called the pour point or gel point.
A 5% biodiesel will raise the cloud point of the fuel about 4 to 5 degrees F (2 to 3 degrees C). A 20% biodiesel will raise the cloud point 5 to 10 degrees F (3 to 6 degrees C). Because fuel passes through the fuel filter before it reaches the suction side of the pump, the expectation is that this type of system would be susceptible to filter plugging due to wax or precipitates.
Are there GM recommended additives that may reduce negatives of biodiesel?
No, at present GM does not recommend any additives. Diesel Fuel Conditioner (p/n 88861009 or p/n 88861038 in Canada) is meant for diesel fuel only. Its effectiveness in biodiesel blends is unknown.
What happens if the customer increases the percentage? 10-20% is apparently available on the street.
An increase in percentage will raise the cloud point of the fuel. It can also cause compatibility issues with elastomeric (rubber-like) constituents. And if the base biodiesel is out of spec then it will worsen the problems caused by bad biodiesel.
Where can information be obtained about what the major fuel distributors are blending and offering for sale in various geographic areas?
Check out the National Biodiesel Board website (http://www.biodiesel.org) for maps of producers and retailers. There are also lists of what products are sold at each retail location.
What are the state or Federal requirements for filling stations to post blending percentages?
At present, pump labeling is an individual state issue. There is no Federal mandate to label biodiesel pumps.
- Thanks to Shailesh Lopes and Andrew Buczynsky
  • 5 years later...
"Biodiesel"-labeled pumps are popping up around Iowa at the same time ethanol is being added to Premium gas around Iowa. I now have to travel across town, and I will, to get non-ethanol 91 octane for motorcycles and PWC (Thank you Caseys at 86th Street and I-80); and it looks like I will have to find a station where I don't have to purchase Biodiesel for my 2500. Way to go Iowa lawmakers...thanks for disregarding manufacturer recommendations for your own political gain.
Only ever witnessed one gas station selling a biodiesel blend and i don't know the exact calculation into $/gallon but it was somewhere around $6 a gallon. No thanks. Ill stick with my nice cheap low sulphur
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 310 Guests (See full list)
