88 K1500
Alright I too leaks. Good thing is they were right on the valve cover. PCV and something else (maybe fuel).
Well my question is on the right side, looking under the hood (opposite PCV) what is that tubing coming out of the valve cover? Is it easy to be fixed?
It looks like its leaking because I went mudding and everything got a thin layer of dirt. Thats when I saw the leaks. PCV was cracked and obviously blowing pressure out all over that side of the valve cover. The other side is more wet and sometimes smells like gas.
What is that tube?
perhaps pics would help???? I am a little confused on what you are referring to.....
350 motor.
Left side has PCV and right side has a tube. What is that tube do?
Is the tube made of rubber or is it semi-metallic and connected to the bottom of the air cleaner housing?
350 motor.
Its made of rubber and connect under the air filter.
350 motor.
refer to post #5
