Poor 4x4 Indication 2008 Sierra
I have a 2008 Sierra 2500HD with electronically controlled 4x4.
The 4x4 control knob is the only place that tells you if you are in 4 wheel drive or 2 wheel drive. This is done by a very tiny light in the knob itself. It is difficult to see.
Already, I have driven about 60 miles in 4x4 high on dry hardtop because I was not aware I was in 4x4.
I was wondering if anyone else has found this poor 4x4 indicator to be a problem?
There is supposed to be an indicator in the dash if you have a "Manual" 4x4 to show you when it is engaged. I wonder if there is a way to tie the electronic indication into this dash indicator?
The indicator light on the 4wd knob is very tiny. You have to check twice to see it sometimes. I feel your pain. Not sure if there is anything that can be done though :D
Welcome to the site :confused:
i agree too, but you should know weather ya put in 4x4 or not plus if you was on dry pavement and tried turning you would defiantly know it was in
I talked to a bunch of people who found themselves still in autotrac months after the snow was gone...light is way to small/dim.
It's a pathetic "design" for sure. There should be an indicator lamp on the instrument cluster that makes it plain that you are in 4WD. Every other 4x4 vehicle I have been in had one.
While I agree the indicator light may be a little small....Are people really this dense?^^^
I could have no light/indicator at all and I would know where my truck is set. Maybe I am more in "tune" with my truck than the average Joe, but I can tell by sound alone when I am in Auto4wd.
Those damn big titties get me flustered everytime I see them. ha, ha
LOL maybe i should change it then
:D Me too!!! Now change that avatar to one without a shirt. :confused:
ok ask and you shall receive LOL
OK....Now change it to one without a bra! :confused::confused:
BTW...I agree,There should be an indicator light on the dash.
Although most of the time I can tell if I'm in 4-high or "auto" 4wd.
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 876 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
