Vin Check
:thumbs: I guess I'm a dumb a??. A VIN number would help. That's what I get for
being in a hurry.
1GCEK19Z25Z218774
being in a hurry.
1GCEK19Z25Z218774
Hahaha! I was just about to post "I think you need a VIN number first"
edit: Just a question - how do you like your mudflaps? I was thinking about picking up some
being in a hurry.
1GCEK19Z25Z218774
They are not bad looking, fairly easy to install, helps keep rocks off of the paint and the gold bowtie on the rear ones accent the bowtie on the tailgate.
They are the molded ones.
Front GM PN: 19154776
Rear GM PM: 19154777
being in a hurry.
1GCEK19Z25Z218774
GM Vehicle Inquiry System
Summary
VIN : 1GCEK19Z25Z218774
VEHICLE INFORMATION
Merchandising Model : CK15753 -2005 SILVERADO 1500 4WD EXT CAB Z71 Warranty Start Date : 05/17/2005
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : BROCKHOEFT S CHEVROLET, INC.
PO BOX 217
GROSSE TETE , LA 70740-0217
(225) 648-2396
Selling Source : 13 - CHEVROLET
Site Code : 24057
Business Associate Code : 114300
Service Contract : Yes
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/17/2005 10 miles 05/17/2008 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/17/2005 10 miles 05/17/2011 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/17/2005 10 miles 05/17/2013 80010 miles
36/36000 FEDERAL EMISSION 05/17/2005 10 miles 05/17/2008 36010 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/19/2007 325502 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 43992 miles
11/21/2006 315073 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 32078 miles
11/21/2006 315073 # H0207 - DRUM, BRAKE - REAR - BOTH -REPLACE 32078 miles
09/21/2005 290450 # R0760 - RADIO, REMOVE AND REPLACE 11840 miles
09/07/2005 014322 # L2040 - SEAL, EXHAUST PIPE - REPLACE 10755 miles
07/12/2005 014111 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST 3068 miles
07/12/2005 014111 # Z7901 - 1-DAY COURTESY TRANSPORTATION 3068 miles
12/17/2004 A18774 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 06/19/2007 Repair Order Number : 325502 Odometer Reading : 43992 miles
Serviced By : ALL STAR CHEVROLET, INC.
PO BOX 77330
BATON ROUGE, LA 70879-7330
(225) 298-8000 Selling Source : 13 - CHEVROLET
Site Code : 24408
Business Associate Code : 130635
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
06/26/2007 807 01 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 19153614 - SHAFT N
Repair Order Date : 11/21/2006 Repair Order Number : 315073 Odometer Reading : 32078 miles
PO BOX 77330
Site Code : 24408
12/22/2006 754 01 # H0207 - DRUM, BRAKE - REAR - BOTH -REPLACE 19133371 - ADJUSTER Y
12/01/2006 748 01 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE N/A N
Repair Order Date : 09/21/2005 Repair Order Number : 290450 Odometer Reading : 11840 miles
PO BOX 77330
Site Code : 24408
09/27/2005 625 01 # R0760 - RADIO, REMOVE AND REPLACE N/A N
Repair Order Date : 09/07/2005 Repair Order Number : 014322 Odometer Reading : 10755 miles
Serviced By : BROCKHOEFT S CHEVROLET, INC.
PO BOX 217
GROSSE TETE, LA 70740-0217
(225) 648-2396 Selling Source : 13 - CHEVROLET
Site Code : 24057
12/20/2005 649 01 # L2040 - SEAL, EXHAUST PIPE - REPLACE 15077362 - SEAL N
Repair Order Date : 07/12/2005 Repair Order Number : 014111 Odometer Reading : 3068 miles
PO BOX 217
Site Code : 24057
07/29/2005 608 01 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST N/A N
07/29/2005 608 02 # Z7901 - 1-DAY COURTESY TRANSPORTATION N/A N
Repair Order Date : 12/17/2004 Repair Order Number : A18774 Odometer Reading : 0 miles
PO BOX 217
Site Code : 24057
12/21/2004 545 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
VIN 1GCEK19Z25Z218774
VEHICLE BUILD
Gross Vehicle Weight Rating : 2906 kg (6408 lb)
Order Number : HNQVQV
Build Date : 12/17/2004
Build Plant : 15Z53
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - 40/20/40 SPLIT BENCH RECLINING FRONT SEAT
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM7 - FOLDING REAR SEAT
AU0 - KEYLESS REMOTE DOOR LOCK
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B71 - WHEEL FLARES
B85 - BRIGHT BODY SIDE MOLDINGS
CJ3 - AIR COND., DUAL ZONE MANUAL
C49 - ELECTRIC REAR WINDOW DEFOGGER
C7H - GVW RATING - 6,400 LB
DF5 - ISRV MIRROR W/COMPASS & TEMP
DK7 - INTERIOR CUSTOM ROOF CONSOLE W/ MAP LIGHTS
DL8 - DUAL PWR HEATED OSRV MIRRORS
EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY
FE9 - 50-STATE EMISSIONS
FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT
FWI - FORT WAYNE PLANT
GU6 - REAR AXLE 3.42 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JF7 - BRAKES, 17" DISC/DRUM
KG3 - 145 AMP ALTERNATOR
KNP - HD AUX TRANS. COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
L59 - VORTEC 5300 V8 FLEX FUEL ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION
NP2 - MANUAL SHIFT TRANSFER CASE
NP5 - LEATHER WRAPPED STEERING WHEEL
NT9 - EMISSION SYSTEM FEDERAL TIER 2 PHASE OUT
NZZ - OFF ROAD - SKID PLATES
PDU - LIGHT DUTY POWER PACKAGE: *VORTEC 5.3L 310HP ALUM BLK V8 *LOCKING DIFFERENTIAL-REAR AXLE *HD TRAILERING EQUIPMENT
P25 - 17" ALUMINUM WHEELS
QJM - P265/70R17 OOR WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE
R9Z - POMS EXPEDITE-SOLD ORDERS
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
TR3 - CHROME GRILLE
T96 - FRONT FOG LAMPS
UB1 - AM/FM STEREO W/CD & CASSETTE (REPLACES STD/OPT RADIO)
UK3 - REDUNDANT RADIO CONTROLS
UQ3 - ENHANCED AUDIO SPEAKERS
VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XJM - TIRE FRONT P265/70R17-113S WOL R/PE ST TL OOR
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YJM - P265/70R17-113S WOL R/PE ST TL OOR
ZJP - SPARE TIRE P265/70R17
ZY2 - TWO-TONE PAINT
Z71 - OFF-ROAD SUSPENSION
Z82 - HD TRAILERING EQUIPMENT
1SL - Z71 OFF ROAD PACKAGE INCLUDES: * DUAL PWR HEATED OSRV MIRRORS * REAR WINDOW DEFOGGER * WHEEL FLARES * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * ISRV MIRROR W/COMPASS &TEMP * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS
1SZ - LIGHT DUTY POWER PKG DISCOUNT
50U - SUMMIT WHITE
59L - SILVER BIRCH METALLIC
6YH - COMPONENT FRT LH COMPUTER SEL
69D - DARK CHARCOAL
69I - DK PEWTER INTERIOR TRIM
7YH - COMPONENT FRT RH COMPUTER SEL
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : WJB Traceability : 043500317
Date Scanned : 12/17/2004 Time Scanned : 06.17.00 Scan Station : 02
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : U1M Traceability : 341413494
Date Scanned : 12/17/2004 Time Scanned : 02.23.00 Scan Station : 16
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : H2BA Traceability : H2B119642
Date Scanned : 12/17/2004 Time Scanned : 02.23.00 Scan Station : 99
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : YU Traceability : 0BD123375
Date Scanned : 12/17/2004 Time Scanned : 06.27.00 Scan Station : 05
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 5KCD Traceability : 40830290
Date Scanned : 12/17/2004 Time Scanned : 06.22.00 Scan Station : 15
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : WH2 Traceability : N188405
Date Scanned : 12/17/2004 Time Scanned : 07.06.00 Scan Station : 04
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : DH2 Traceability : 024985
Date Scanned : 12/17/2004 Time Scanned : 06.24.00 Scan Station : 03
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YHZS Traceability : 04350EZB5
Date Scanned : 12/17/2004 Time Scanned : 10.23.00 Scan Station : DV
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 1144 Traceability : 00240399
Date Scanned : 12/17/2004 Time Scanned : 07.06.00 Scan Station : 14
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 8212 Traceability : 1EAK0B2
Date Scanned : 12/17/2004 Time Scanned : 07.39.00 Scan Station : 12
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 3522 Traceability : 4331JHSKK
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 3522 Traceability : 4331JHSLQ
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 9602 Traceability : 9YIFQ76
Date Scanned : 12/17/2004 Time Scanned : 02.15.00 Scan Station : 21
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2627 Traceability : 34348Z462
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZS Traceability : 1100699
Date Scanned : 12/10/2004 Time Scanned : 04.09.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1PA Traceability : 3940068
Date Scanned : 12/16/2004 Time Scanned : 11.28.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1KA Traceability : 3949359
Date Scanned : 12/16/2004 Time Scanned : 21.26.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1FA Traceability : 7119359
Date Scanned : 12/17/2004 Time Scanned : 00.20.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 05/17/2005
Delivery Type : 010 - RETAIL/INDIVIDUAL
Delivered Odometer : 10 miles
Delivering Dealer :
PO BOX 217
(225) 648-2396
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 24057
Service Contract
SERVICE CONTRACT
Policy Number : 815143985
Owner Name : KNIGHT
Description : 48/72000 GMPP MAJOR GUARD
Deductible Amount : $ 100
Inception Date : 11/01/2005
Expiration Date : 11/01/2009
Inception Odometer : 13599 miles
Expiration Odometer : 85599 miles
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
