What To Do With 20" Wheels And Tires
Hi, I'm new to the forum and will hopefully be picking up my new truck on Thursday. I've chosen an 08 Sierra SLE2 and plan on doing some mods. They have a truck on the lot that I really like but it has 20" wheels and tires on it. I really don't care for a lot of wheel and no tire. I'm going to 17"s and was wondering where I might get rid of the oem wheels and tires.
Use the for sale section here/ebay/craigslist/another auction site. Post pics when your get your truck and Welcome to GM-Trucks.com
+1. All kinds of places to sell on the internet. Welcome aboard. :thumbs:
Thanks guys, I'm handicapped so they are going to be putting the wheelchair lift and things like that on it but we're looking at Thursday. I'll be buggin y'all for information on exhaust and a cold air box. I've been reading a lot of the posts here and man, what a wealth of knowledge. I look forward to chatting with y'all.
Welcome! TONS of info available here! Good luck with your new truck. BTW - 20's aren't so bad. I was reluctant to go with them on my Denali but they came stock. In hindsight, I don't think the ride suffers at all and they look good IMO.
Ask the dealer to swap for 17's off another truck. Tell him you don't want the truck unless he puts the 17's on. Even if you don't like the rims, you'll still have the right size tire if you decide to chage to aftermarket 17 inch rims. Make sure the 17's he gives you have the TPMS sensors.
When I bought my truck, they had 20's on it that I didn't like. I negotiated with the dealer to have them put the stock 18's on the truck and knock the price of the 20's off the sticker. I would suggest trying that route before you buy the truck and take a beating, trying to sell them.
+1, except it took me a year to figure out they were NEVER going to "grow on me". So, I sold them myself for $900 (stock 20's with tires) with about 9000 miles on them.
I would also suggest having the dealer swap them as long as they are willing to give you credit for them since they are a $1200+ upgrade from 17's.
Geeeez, Jeff hasn't piped up on this yet!!! :):D
Happy now? :D
It's just as surprising that Daddy hasn't "contributed" to this thread yet. :thumbs:
Geeeez, Jeff hasn't piped up on this yet!!! :D:D
Happy now? :D
That-a-boy............now I can rest at ease and get back to work! :rollin::)
Welcome to the site Ray, and congrats on the truck :thumbs: I'll echo what others are saying and suggest that you ask the dealer to swap the wheels out. It's not uncommon for dealers to do this, and it will save you the time of unloading the wheels yourself. If that doesn't work for whatever reason, you shouldn't have any problem at all getting rid of brand new 20" truck wheels on ebay.
Make sure to take some pictures of your new rig and post em on this site eh!
Welcome to the site Ray, and congrats on the truck :rolleyes: I'll echo what others are saying and suggest that you ask the dealer to swap the wheels out. It's not uncommon for dealers to do this, and it will save you the time of unloading the wheels yourself. If that doesn't work for whatever reason, you shouldn't have any problem at all getting rid of brand new 20" truck wheels on ebay.
I'm really looking for something with a wider look and was told that a P285-70-17 was as wide as I could go with the level kit installed. Any suggestions would be greatly appreciated. I'm going to try and post the wheels and tires, tell me what you think.
    HWN808
    HWN808
  • Who's Online   2 Members, 2 Anonymous, 1,036 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
