Classic Silverado Vs. Nbs Silverado
There's a scale close to where I work so with little less then a half a tank of gas and my fat ass, my truck weighed in @ 5,520lbs. Minus me and the fuel that put's my curb weight around 5,200lbs.
Has anyone weighed there 4x4 NBS (New Body Style) V-max or HD?
Josh
Well my '04 GMT800 weighed 4995lbs.,My '99 GMT800 weighed 5049lbs. & my '07 GMT900 VMAX weighs 5329lbs.
But my '07 has more "goodies" than the '04.....pwr.suroof,pwr rear side windows,pwr.rr.sliding window,pwr.pass.seat,block heater,rear park assist,E-Z lift tailgate,etc.,All stuff that adds weight.
By comparison my '97 GMT400 weighed 5074lbs. and it had every option but leather and the factory bedliner....dual batteries,pwr.driver seat,block heater,HD chassis w/the bigger rear-end,etc.
These are/were all 1/2-ton extended-cab short-bed 4x4 Z71's.
Near empty fuel I was just over 6000 pounds.
Is this after all your mods? (Wheels,Lift,Steps,etc.) I can't see a 1/2-ton weighing 6000lbs. stock,but with a lift,step bars and some 20's I could see it being possible.
If you post your VIN I can pull your invoice and see what the shipping weight was from the factory.
Yeah that's its current weight with all the goodies.
VIN 1GTEK19J87Z500415
Its shipping weight was 5,282lbs.(2,396kgs.)
*BTW...You have an OPEN "REQUIRED FIELD ACTION" on your truck,Heres the bulletin for it....
Service Information
Document ID: 1906362
#07033B: Service Update for Inventory and Customer Vehicles-Battery Rundown-Expires with Base Warranty - (Feb 15, 2007)
Subject: 07033B -- Service Update for Inventory and Customer Vehicles - Battery Rundown -- Expires with Base Warranty
Models: 2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon XL
THE SERVICE PROCEDURE IN THIS BULLETIN HAS BEEN REVISED TO ADDRESS VEHICLES WITHOUT A DRIVER INFORMATION CENTER (DIC) AND POWER DOOR LOCKS/WINDOWS, AND A CONDITION WHERE THE ODOMETER READING DISPLAYS METRIC UNITS INSTEAD OF ENGLISH UNITS.
TECHNICIANS MAY EXPERIENCE SLOW PERFORMANCE USING THE TIS2 WEB APPLICATION WHEN REPROGRAMMING THE VEHICLE TO CORRECT THE CONDITION. TECHNICIANS MAY NOTICE THE SLOWER APPLICATION PERFORMANCE FROM MID-MORNING UNTIL LATE AFTERNOON.
TO ASSIST IN IMPROVING PERFORMANCE AND REDUCE PROGRAMMING TIME, IT IS RECOMMENDED TO COMPLETE THE BULLETIN PROCEDURE ON CUSTOMER VEHICLES FIRST. VEHICLES IN INVENTORY SHOULD BE PROGRAMMED DURING OFF PEAK HOURS IF SLOW PERFORMANCE IS EXPERIENCED.
Purpose
This bulletin provides a service procedure to reprogram the body control module (BCM). On these vehicles, and under certain conditions such as operating the radio with the engine off, the battery can become discharged, preventing engine start-up.
This service procedure should be completed as soon as possible on involved vehicles currently in dealer/retailer inventory and customer vehicles that return to the dealer/retailer for any type of service during the New Vehicle Limited Warranty coverage period.
Vehicles Involved
A list of involved vehicles currently in dealer inventory is attached to the Administrative Message (US) or Dealer Communication (Canada) used to release this bulletin. Customer vehicles that return for service, for any reason, and are still covered under the vehicle's base warranty, and are within the VIN breakpoints provided below, should be checked for vehicle eligibility in the appropriate system listed below.
Year
Division
Model
From
Through
2007
Cadillac
Escalade
7R100158
7R350607
2007
Cadillac
Escalade ESV
7R136311
7R350603
2007
Cadillac
Escalade EXT
7G100001
7G274360
2007
Chevrolet
Avalanche
7G100002
7G274351
2007
Chevrolet
Silverado
71500002
71606869
7E500001
7E513617
7F500001
7F500145
7G500016
7G506215
7Z500001
7Z549763
2007
Chevrolet
Suburban
7G100004
7G274344
7J100041
7J318223
7R136280
7R350609
2007
Chevrolet
Tahoe
7J100002
7J318216
7R100001
7R350613
2007
GMC
Sierra
71500001
71606870
7E500003
7E513603
7F500004
7F500140
7G500017
7G506220
7Z500002
7Z549756
2007
GMC
Yukon
7J100040
7J318228
7R100040
7R350611
2007
GMC
Yukon XL
7J108390
7J318203
7R137014
7R350599
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using GMVIS. Not all vehicles within the above breakpoints may be involved.
Service Procedure
Important: Technicians may experience slow performance using the TIS2 web application when reprogramming the vehicle to correct the condition. Technicians may notice the slower application performance from mid-morning until late afternoon.
To assist in improving performance and reduce programming time, it is recommended to complete the bulletin procedure on customer vehicles first. Vehicles in inventory should be programmed during off peak hours if slow performance is experienced.
Important: The calibration numbers required for this service procedure are programmed into control modules via a Techline Tech 2® scan tool and the Techline Information System (TIS) terminal with the calibration update. Use TIS 2 Web version 2.0 for 2007 (available on 02/04/07) and on TIS DVD version 2.0/2007 or later, that was mailed to dealers on 02/14/2007. If you cannot access the calibration, call the Techline Customer Support Center and it will be provided.
Notice: Before reprogramming, please check the battery condition to prevent a reprogramming error of any of the modules due to battery discharge. Battery voltage must be between 12 and 16 volts during reprogramming. If the vehicle battery is not fully charged, use jumper cables from an additional battery. Be sure to turn off or disable any system that may put a load on the battery, such as automatic headlamps, daytime running lights, interior lights, heating, ventilation, and air conditioning (HVAC) system, radio, engine cooling fan, etc. A programming failure or control module damage may occur if battery voltage guidelines are not observed.
The ignition switch must be in the proper position. The Tech 2® prompts you to turn ON the ignition, with the engine OFF. DO NOT change the position of the ignition switch during the programming procedure, unless instructed to do so.
Make certain all tool connections are secure, including the following components and circuits:
• The RS-232 communication cable port
• The connection at the data link connector (DLC)
• The voltage supply circuits
DO NOT disturb the tool harnesses while programming. If an interruption occurs during the programming procedure, programming failure or control module damage may occur.
DO NOT turn OFF the ignition if the programming procedure is interrupted or unsuccessful. Ensure that all control module and DLC connections are secure and the TIS terminal operating software is up to date.
Tech 2 Pass-Thru Method for the Body Control Module (BCM)
Verify that there is a battery charge of 12 to 16 volts. The battery must be able to maintain a charge during programming. Use an additional jump battery if necessary.
• If the vehicle will not start, test and charge the battery. Refer to SI for battery testing and charging information, if required.
• If the battery will not hold a charge, replace the battery. Do NOT replace the battery unless it can’t be charged or a leak and/or physical damage is present.
Connect the Tech 2 to the vehicle and the TIS terminal.
Turn the ignition to the ON position with the engine OFF.
After all warning chimes inside the vehicle have stopped, turn on the Tech 2.
On the TIS terminal go into SPS Programming.
Select Pass Thru programming.
Follow instruction on the TIS terminal. When you get to the Supported Controllers screen.
7.1. Scroll down in the top box and select BCM (Body Control Module).
7.2. In the lower box select Normal.
7.3. Select Next.
Important: Vehicles without the Driver Information Center (DIC) and power door locks/windows will have two calibrations from which to choose. A selection is requried before you can select NEXT. Select calibration 25814828. Do not select calibration 25788372.
Select NEXT when the calibrations screen displays.
Follow on-screen prompts until programming is completed.
When programming is complete.
10.1. Turn off Tech 2.
10.2. Turn the ignition switch to the OFF position.
Wait 30 seconds.
Turn the ignition switch to the ON position with engine OFF.
Turn on the Tech 2.
Go into diagnostics and check for DTC codes.
Clear all codes.
Important: Failure to successfully reprogram the BCM may result in the odometer displaying mileage in metric units instead of English units. To reset the odometer to display mileage in English units, remove the 10 amp fuse from the underhood BEC. Do not reinstall the fuse for 5 minutes.
Important: After reprogramming the body control module (BCM) the driver information center (DIC) will display tire pressure values as dashes. Do not perform the Tire Pressure Monitor Reset procedure. The Remote Control Door Lock Receiver (RCDLR) will update the instrument cluster with tire pressure values during the next driving event. The vehicle must reach a speed of 40 km/h (25 mph) in order for the RCDLR to update the display.
Claim Information
For vehicles repaired under this service update, use:
Labor Operation
Description
Labor Time
Y0152
Reprogram BCM
0.4
Add: Test & Charge Battery
0.2
Add: Test & Replace Battery
0.4
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
That's with him at the wheel. The truck itself weighs only 5400 lbs. :D
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
