Fan Speed Switch And A/c?
On my 2000 rcsb silverado I'm having a/c problems and this time of the year I'd like to get it fixed asap. The fan speed switch only works on the number 5 speed. My guess would be its jsut the switch in the dash. What do you guys thinks? If it is, is that a part you can only get from a dealer/salvage yard or a local auto parts store by chance?
Also, my a/c does not blow cold at all. I looked under the hood and at the condensor I believe its called has a plug in and then there is a plug in dangling buy it. It is also missing both the caps the cover where they fill the system or what not. So, someone has apparently messed with it. Is there a chance just getting a shop to fill it back up will correct this? Or am I looking at something bigger?
Sorry for lack of technical terms never dealt with them a whole lot. All the cars I've owned before either didn't have it and wasn't worth looking into or had it and never had any issues.
Thanks in advance!
Kyle
Thanks in advance!
Kyle
The fact that the schrader caps that cover the test/fill points are missing and the general state of dissarray, I would highly recommend a professional look the system over. There is no telling what an amateur has done up to the is point. The missing fan speeds are probably due to blown resistors, a simple fix that a real technician can handle along with the more technical mysteries you've outlined.
Does the local quicklube count as a professional? I know a few gujys that work there and they always seem to know their stuff. They only let the good ones touch like that. lol. Or would I be better of going to a dealer?
Good a/c techs are all around, if you trust the quicklube guy and they're reasonable there's nothing so unique about a GM a/c that any qualified tech wouldn't know about. The main thing is diagnosing without causing additional problems and fixing the real problems without wasting money.
Your fan speed problem is more than likely a bad blower fan resistor board. It is located in the duct under the dash right by the fan.
The A/C not getting cold is probably low freon. You whould have the system checked out for leaks and then a re-charge.
Is there anyway to know for sure if that resistor board is bad? Can someone post a pic of where its located?
I'll make an appointment out there hopefully I'll get it in this week.
Kyle
I got the a/c took care of today along with a tranny leak and squeaky pulley. Now that I got the part numbers and the how to I just need to pick up the part.
Thanks guys! You all have been a great help so far!
Kyle
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
