2006 Cc Z71 Suspension Questions
scottmoyer
Not sure how to address this as I've seen so much posted and don't know what to do.
The rear of my truck seems to continue bouncing after going over speed bumps or just cruising on certain road surfaces. What inexpensive option is there to stop this? I had helper springs installed incorrectly and the ride was great. When I corrected the install, it got sloppy again. I've heard of diffferent types of helper springs can fix this. I also heard that different shocks will fix this. Which ones? I have an IROC-Z so I prefer a sport suspension over soft, and bouncy is too much. I've read about add a leafs and swapping in 2500 series leaf springs. I don't remember this as an issue on my old 2001 Z71. Any suggestions?
My next issue is the new tires. I have been getting them rotated every 5k miles and the edges are still feathering/cupping like the factory tires did. The tire shop recommended that I replace the shocks. Is it that easy to fix this? My last rotation showed that I may have a bad tire as the truck is now pulling to one side and I am bouncing all over the road. The tire shop put the tires back where they cam from and the truck tracks straight, the steering wheel is straight and minimal bounce on smooth roads.
I just want the truck to ride firm, take the road bumps better and stop trashing my tires. I'd prefer not lifting the truck by doing add a leafs, but if I have to, then I'll also get the coil spring seats that raise the front a little to keep the truck level. Thanks for any help.
When is the last time you had your front end aligned? I ate up a set of tires on my 02 due to the alignment being off and she drove nice and straight and the steering wheel was centered....doesn't matter on these trucks. I now get mine checked at least once a year. I don't think shocks are going to fix your tire feathering problem.
I've had the alignment done at least 6 times in the last 10 months. I bought the 1 year alignment package when I got the new tires. The tires seem balanced and the alignment is good. That's what is driving me crazy. With balanced and aligned tires and front end, I shouldn't continue getting the outer edges of the tires worn, but they are.
You might consider taking it to another alignment shop and let them take a look at it before the tires are trashed. Like I said I ate up the last set of tires on mine in only 26K miles due to the inner edges wearing badly and I thought my front end was fine. Wish I could be of further assistance.
I take that back...it was the outer edge and not the inner edge that wore prematurely. I could actually see the bottom of the tires tilted inward when my truck was sitting in the driveway but thought everything was fine since it was driving perfectly. When I finally took it in to get it checked the alignment tech spent about 2 hours adjusting and driving before he was satisfied it was correct. Unfortunately the tires didn't last much longer after that. I now have a set of Bridgestone Alenzas on the truck and once again had the same guy do the alignment and so far everything is fine. I also purchased the lifetime alignment and get it checked every 6 months now.
As far as the shocks go I don't see them causing your tire issues but they are extremely easy to change. Lot's of folks here like the Bilsteins, KYB's, etc. I've got the Rancho RSX on my truck and they were a vast improvement over the stock shocks. I replaced mine at 40K miles and the stockers were trashed as far as i'm concerned. New shocks should help w/ the rear end bounce and with the front end roll.
I've had the front end aligned by 3 shops. All 3 shops make adjustments to what the other did. I took the truck to the dealer after I bought it because I too could see the top of the tires were out further than the bottom. They said it was fine, but my tires keep wearing. I still have that angle on the tires, but it's within spec.
My truck has 54k miles and I've been fighting this tire issue since day one. The rear end is getting bouncier, but that could also be attributed to a bad tire. As I stated, when the tires were rotated last, the truck bounced around all the time and there was wheel pull to the right. The shop checked the alignment and it was good. They swapped the tires back and the wheel was straight and the bouncing stopped. The bouncing of the tires is a different bounce than "frame beaming" or jounce that I would also like to get rid of. Thanks for the suggestions. Which shock would provide a firmer but better ride? My IROC-Z "feels" the road, but doesn't jar on the bumps. I'd like something to that effect.
I bet your tire wear has to do with the leveling you have done to the front end. I bet the shops are not adjusting your a-arms, etc correctly. When you look dead straight at the front of your truck from about 30-50 feet, can you tell if the bottom of your front wheels are angled inward or outward? If inward, then you know your answer. They have not adjusted the camber correclty to compensate for the leveling. That was the problem I had when I had my truck leveled in the front, and I have a 06 CC Z71.
As amatter of fact, I have the same bouncing you are talking about, too. I have 42k on mine and I think I am ready to try new Bilstein shocks and dump the originals.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
