Replacement Tailgate
All: Need a replacement for a 2006 Sierra 2500HD tailgate.
What is general opinion of after-market tailgate shell (that would need priming and painting) vs looking for a good recycled unit (hopefully an OEM unit) from a wreck? If the latter, what year(s) gates will fit a 2006 Classic body 2500?
My tailgate hardware in good shape,(altho missing GMC & Sierra lettering) but inner skin badly dented and 1-1 1/2 inches away from box edge at centre. Stuff falls out!
Thx for your help. Jeff
They actually upgraded the brackets since 99, but you can buy the tailgate side bracket, or even take it off your current tailgate, it will all match up installation wise. The only difference I could see was the old ones were hollow and the new ones are solid, but they insist you need both the bed and tailgate part of the hinge. But ya enough ramblin, just unbolt the one from your current tailgate and bolt it on to the replacement.
My limited experience with aftermarket tailgates is that they're poor quality overall and much less durable, being manufactured from thinner gauge sheetmetal. I strongly recommend going with an OEM tailgate, be it new or from a salvage yard.
I had a problem with a dent on the outside of my tailgate on my 2003 1/2 ton. I watched ebay for one that matched perfectly. I found one from a 2005 3/4 ton that fit without out a problem. It probably took me 2 months to find the right one but it cost me about $380 by the time it was over but it matched the truck and fit perfectly. I would keep your eye out for a used on that matches. The quote to fix my dent was $800 and I think $400 of the cost was just for paint.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
