Ac Problem With 2004 Suburban - Very Odd
greywolf2112
I have a 2004 Suburban, 8.1L engine, LT model that is loaded. Has the automatic climate control, etc.
Lately, it has started having an issue with the AC. I'll start the vehicle, and like it has always done it will wait about 2-3 minutes before the AC kicks on (this is normal). It will quickly ramp up to whatever fan speed it needs, and then run sometimes for 5-15 minutes (sometimes longer), nice and cold. Then, suddenly, its like someone switched it over to the HOTTEST heater setting there is. Nothing but blistering hot air coming out the vents.
Turning it off and then on again doesn't change it back. Kicking the auto temp higher or lower doesn't help. Turning it over to HEAT and then back, turning off the AUTO, none of it works. After I've parked it for a few hours, it goes back to operating normally again (for 5-15 minutes) and then starts the problem all over again.
Bad relay switch? Computer? Freon about gone? I'm at a loss here. Obviously need to take it in to the mechanic, but afraid of the possibilities. Vehicle only has about 60,000 miles on it.
If it gets cold for a while, the freon level is likely not the issue. Your evaporator core could be freezing up. Or it could be an air mix motor issue... Or maybe the brains of the auto climate control. One of the pitfalls with auto stuff in general is the fact that it is harder to diagnose and repair.
I'd let a mechanic that is familiar with GM auto climate control look at it. A general knowledge mechanic will likely chase his tail for a while figuring it out.l
My 04 Sierra is doing the same thing, just wondering if you have figured out a fix for it yet? I'm thinking it is an electrical issue somewhere, maybe a bad ground or solder joint somewhere which makes the climate control default to full heat???
I have had a few trucks lately that have done this and it has turned out to be the mix door actuator. Luckily, both it was the left side control which is on the bottom of the case and easy to get at.
Did you replace the actuator, or just reset them?
It kinda sounds to me like you might have some sort of short in your wiring have you tried having a auto electrician lookin at it? I had some work done on mine recently and he found the problem in about 30 min i would say find a good one near you and give them a try to figure it out thats the only thing i can think of
My problem is very random, in has only happened a few times over the last several months. But when it happens, I can't get cold air again until I turn off the engine and restart it. I'm waiting until it happens again to check if the passenger side goes hot too, this one may be hard to figure out.
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
    • Triumph makes me think of cars not bikes. Especially with model names like the TR7, that was a Triumph car model too. Peak TR for me was the TR250. You could retain the post-war roadster looks, with an optional surrey hard top, but with an inline 6 engine instead of the TR4's anemic 4-cylinder, but still have a 4 speed, optional overdrive.   I know almost nothing about Triumph bikes, except that they exist. Good looking bikes though.   I don't know if I could just have one vehicle. The Silverado does it all except for fitting anywhere. But it leaves a void in real driving enjoyment, unless driving an extremely large sofa is your thing.   What did I do to my 'other' (muslce car - which one!?) vehicle lately. I took my '23 SS for a drive. It's only got 1600 miles. I keep reminding myself I shouldn't be so precious about this car. It likes to be driven. Needs to be driven. Life is short and if I don't enjoy it, someone else will. The other half calls it "the garage ornament".
