Fs Nbs Weathertech Floor Liner
weathertch floor liner in blk for the front on the NBS 07/08 Silverado. Several months old, sold truck. List $99. $50 plus shipping. I also still have A ECM/TCM which was previously listed. Make offer.http://www.weathertech.com/store/mvproduct.aspx?ItemGroupId=52&VehId=147&Year=2008&VehOptChoiceIds=28,128,686
How much for the PCM/TCM?
give me a day or so as someone has committed to buying it but I haven t been paid yet.
I'll step in line for the PCM/TCM as well.
