Auto Transfer Case?
Question on transfer case fluid level? I change the Oil in my 2004 K1500 Silverado w/ auto transfer case. When I pulled the fill plug, I got about 1.5 to 2.0 quarts of reddish blue fluid out. Then I pulled the drain plug to drain the rest of the fluid. All fluid removed totals about 3.5 to 4.0 quarts. Manual states fluid level just below fill plug. When I replaced with 1.8 liters of Auto-Trak II fulid. My question is was the transfer case over filled at the factory, or could the auto transmission be leaking into the transfer case?
Sounds like the trannsmission fluid is leaking into the transfer case,The transfer case fluid should have been Blue...Not Reddish-Blue,And it should have only had 2 quarts of fluid in it,Not 4.
None,to very very little fluid should have come out when you pulled the fill plug.
BTW.....Check your transmission fluid,I bet its a couple quarts low!!
Thanks MS3DALE, Trans fluid is low. I guess I will be going by the dealer tomorrow. Do you think the transfer case will need to be flushed out? Anything else I should know before I see the GM Dealer?
Yes,If the transmission fluid is leaking into the transfer case I would flush out the fluid once you get the leak repaired and put fresh AutoTrakII fluid in.
  • 9 months later...
I'm changing the transfer case fluid on my 06 Sierra 1500 and saw your comment that very little fluid should come out the drain plug, this seems odd since it takes two quarts to fill. Where is the rest of the fluid? When I pulled the plug on mine the same thing happened, very little fluid came out, I'm reluctant to pour two quarts of fluid in there without getting more out. Is there a second drain plug somewhere?
He said fill plug, not drain plug.
If you got very little, then there is an issue. The drain is at the bottom.
I can confirm, they do hold 2 quarts, and that is what you should have drained.
Any idea on what issue I might be looking at, there were no visable leaks to the Tcase, could it be leaking in the transmission? Or maybe it was never filled right to begin with. I bought the truck used last fall so who knows what the previous owner did.
Not possible. It would not leak into the transmission. If there was a leak at that seal, you would have trans fluid in the t-case, and the t-case would be over full.
The previous owner must have not filled it properly.
That's what I'm thinking, are you in Anchorage? I'm in Fairbanks.
I am right now. We are in the middle of relocating to Oregon. House sale should be closing on the 16th.
  • 4 weeks later...
It is possible. If the pilot bearing in the input gear of the transfercase walks aft the mainshaft in the transfercase can wear hole in the bearing cup. The transfercase then pumps oil into the transmission.
On a 246 mated to a 4l60? I have heard of this on older models (non auto NVGs), but I didn't think the input bearing on a 246 had the lube pressure from the pump.
Input bearing doesn't have direct lube from the pump, but the pilot bearing does. Oiling system is pretty much the same as on a part time except there is a restrictor in the end of the mainshaft to put more oil through the clutch. If the pilot bearing leaks the oil doesn't have to get past the input seal as the oil bypasses the seal inside of the input gear.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
