Stuck In 2nd
MrGoodWreck
2005 Silverado SS - Engages hard into gear (both forward and reverse). Starts in third unless you pull it into low (1). When pulled into "1" it starts in 2nd and will shift to third when put in 3 or Drive. If left in 3 it will accelerate and decelerate with the engine. In Drive it will free wheel when off the gas.
It's been intermittant and now is a hard fault. Codes are P0 740, 753, 758, 761, 785 and P2761. It seemed to have the problem if the first thing I did was back up after starting.
It has power on pin E at the trans (pink wire). I dropped the pan and there is power to each solenoid. How do I troubleshoot the ground paths back through the PCM ? Any help out there ?
:cool:
The odds of all those codes being set are slim unless the the plug is off the side of the transmission. What did you use to test the power at the solenoids? If it was mine I would put a switch in it. They are very cheap- retail GM is $40 or so.
Thanks - I inspected and cleaned both the trans connector and PCM connector. I measured voltage at the solenoid pins inside the trans so I conclude that the connector is not the problem - at least on the power side of the circuit. When this was first happening intermittantly, I replaced the switch module on the left side of the trans. but no change.
I think it must be on the ground side of the control circuit. They are all grounded through the PCM as far as I can tell. I also cleaned all the wire harness ground points on the chassis.
Any other thoughts ?
  • 1 month later...
Replace the ignition switch
It is problem that has to be explaind to understand
First of all the IGN 0 fuse in the fuse block inside the vehicle powers the 1 pink wire to the transmission connector. There must be battery voltage at that wire... 12 volts ... no less
now that 1 wire splits up into 5 wires to power all the solenoids in the transmission.
Each of the solenoids have their own ground through the pcm
When all these codes set it is hard to believe the pcm is the issue due to 5 seperate ground wires (possible but unlikely) What ususlly happens is an interminent short in the ignition switch the powers the ING 0 fuse
this short or open only has to last for 3 seconds and the code pops
during this time the power can go back to normal (switch powers the correct voltage) but tranny goes into limp mode untill codes cleared
so my advice put in a 50 dollar ignition switch
and let me know how it works out
+1 on the switch, if it is a hard fault now you can check that circuit. If it was intermittant I would throw one at it based on about 100:1 odds. If it's happening now check out the circuit just to be sure.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
