Service Work
hi, i am new to this site. i just got a 2006 gmc sierra 1500 z-71 crew cab. i like the truck so far. i have had 4 chevrolet's in the past, but this is the first gmc. i wonder if it is something bad if the truck squeeks? like in turns or at take off, also could i get a vin check (for service history) for free? i hope someone could help me. thanks so much.....ed
Welcome!! :cool:
Post the last 8 digits of your VIN (It will start with a "6") and I'll run a build sheet/warranty service history/delivery info. for you.
GMC and Chevy are the same truck, so if you liked your Chevy trucks, yuo'll likely like the GMC.
You don't give us much to go on there but... Many squeaks on GMT800 trucks could be traced to body mounts. It was a pretty common issue. Some squeaked when taking off, stopping, or going into a driveway when the truck twists a little. I had the same problem on 2 of my 800 trucks. Loosening the bolts and re-tightening them with an impact usually took care of it on mine.
Welcome!! :cool:
thanks so much. 61333488
thanks for the input. it sounds like the same issue. i was hoping it wasn't from damage. not only is this the first gmc, but first white truck.(all other vehicles have been black) it has not got 2 hot in georgia yet, but it is cooler inside the truck..ed
Here ya' go...It has an open recall,and the tranny and steering gear were just replaced not long ago under the previous owners GMPP extended warranty (Sometimes it does pay to buy an extended warranty!!)..........
GM Vehicle Inquiry System
Summary
VIN : 2GTEK13Z261333488
VEHICLE INFORMATION
Merchandising Model : TK15543 -2006 SIERRA 1500 4WD CREW CAB SLT
Warranty Start Date : 07/28/2006
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
HEYWARD ALLEN MOTOR COMPANY, INC.
PO BOX 5519
ATHENS , GA 30604-5519
(706) 549-8580
Selling Source : 48 - GMC TRUCK
Site Code : 53509
Business Associate Code : 117561
Service Contract : Yes
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
YT 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 06/26/2007 >>Open<<
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped No
OnStar Status N/A
Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes
XM Radio ID DE1XH04N
XM Status Inactive
Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 07/28/2006 0 miles 07/28/2009 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/28/2006 0 miles 07/28/2012 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/28/2006 0 miles 07/28/2014 80000 miles
36/36000 FEDERAL EMISSION 07/28/2006 0 miles 07/28/2009 36000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
02/18/2008 154406 0 K7000 - TRANSMISSION ASSEMBLY - REPLACE 38917 miles
02/18/2008 154406 0 T2020 - TOWING 38917 miles
02/18/2008 154406 0 E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 38917 miles
02/18/2008 154406 0 D1811 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - RIGHT 38917 miles
02/18/2008 154406 0 Z7905 - 5-DAY COURTESY TRANSPORTATION 38917 miles
12/05/2006 139813 # B4365 - ROD, FRONT DOOR LOCK CYLINDER TO LOCK - LEFT - R&R OR REPL 10665 miles
12/05/2006 139813 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10665 miles
08/16/2006 136136 # B9640 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - RIG 2201 miles
04/20/2006 132047 I Z6998 - PDI ADDS 3 miles
04/13/2006 A33488 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 02/18/2008 Repair Order Number : 154406 Odometer Reading : 38917 miles
Serviced By : HEYWARD ALLEN MOTOR COMPANY, INC.
PO BOX 5519
ATHENS, GA 30604-5519
(706) 549-8580 Selling Source : 48 - GMC TRUCK
Site Code : 53509
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
04/04/2008 888 01 0 K7000 - TRANSMISSION ASSEMBLY - REPLACE 89037492 - TRANS REM
03/21/2008 884 02 0 T2020 - TOWING
03/21/2008 884 03 0 E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 88965542 - S/GR REM
03/21/2008 884 04 0 D1811 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - RIGHT 89018365 - ACTUATOR
03/21/2008 884 05 0 Z7905 - 5-DAY COURTESY TRANSPORTATION
Repair Order Date : 12/05/2006 Repair Order Number : 139813 Odometer Reading : 10665 miles
PO BOX 5519
Site Code : 53509
12/19/2006 753 01 # B4365 - ROD, FRONT DOOR LOCK CYLINDER TO LOCK - LEFT - R&R OR REPL
12/19/2006 753 02 # Z7901 - 1-DAY COURTESY TRANSPORTATION
Repair Order Date : 08/16/2006 Repair Order Number : 136136 Odometer Reading : 2201 miles
PO BOX 5519
Site Code : 53509
08/25/2006 720 01 # B9640 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - RIG 15844158 - LAMP
Repair Order Date : 04/20/2006 Repair Order Number : 132047 Odometer Reading : 3 miles
PO BOX 5519
Site Code : 53509
04/28/2006 686 01 I Z6998 - PDI ADDS
Repair Order Date : 04/13/2006 Repair Order Number : A33488 Odometer Reading : 0 miles
PO BOX 5519
Site Code : 53509
04/18/2006 683 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Vehicle Build
VIN 2GTEK13Z261333488
VEHICLE BUILD
Gross Vehicle Weight Rating : 3178 kg (7007 lb)
Order Number : JXZM25
Build Date : 04/13/2006
Build Plant : 26143
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - POWER DRIVER SEAT ADJUSTER
AG2 - POWER FRONT SEAT ADJUSTERS
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AM7 - FOLDING REAR SEAT
AN3 - FRT FULL-FEATURE RECLINING BUCKET SEATS - LEATHER
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
BVS - BLACK TUBULAR ASSIST STEPS ***DEALER INSTALLED***
B30 - FULL-COLOR KEYED CARPET W/MATS
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR-KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
CJ2 - DUAL ZONE AIR COND - AUTO
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5W - GVW RATING - 7,000 LBS
DF5 - ELECTROCHROMIC ISRV MIRROR WITH COMPASS & TEMP
DK7 - OVERHEAD CONSOLE
DL3 - OSRV MIRRORS W/PWR FOLD & ADJ, HEAT & TURN SIGNAL; ELECTRO- CHROMIC DR-SIDE MIRROR
DNR - DEALER INSTALLED EQUIPMENT
DT4 - SMOKER'S PACKAGE
D07 - FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E63 - WIDESIDE BOX PICKUP BED
FE9 - 50-STATE EMISSIONS
FF6 - TORSION BAR SPRING ADJ - LH
FF7 - TORSION BAR SPRING ADJ - RH
GU6 - REAR AXLE - 3.42 RATIO
G80 - H.D. REAR LOCKING DIFFERENTIAL
JF3 - POWER DISC BRAKES W/ABS
JJG - FRT END SUBASSEMBLY
KG3 - ALTERNATOR 145 AMP
KNP - H.D. TRANSMISSION OIL COOLER
KUP - THROTTLE CONTROL ELECTRONIC
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
L59 - VORTEC 5.3L V8 FLEXIBLE FUEL ETHANOL ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE
NP5 - LEATHER-WRAPPED STEERING WHL
NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE
NT8 - FEDERAL EMISSION SYSTEM
NZZ - OFF-ROAD SKID PLATE PKG
OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
P27 - 17" POLISHED CAST ALUM. WHEELS
QJM - P265/70R17 OOR WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE
R6J - CUSTOMER DIALOGUE NETWORK
R6P - PREMIUM PAINT
R6S - L59 ETHANOL ENGINE ID
R8K - *******************************
R9N - LEATHER SEAT TRIM
R9Z - POMS EXPEDITE-SOLD ORDERS
SLM - STOCK ORDERS
SSB - SUB ASSEMBLY INSTALLED
TFE - SALES INCENTIVE-COMMITMENT PLUS
T96 - FRONT FOG LAMPS
UC6 - AM/FM STEREO W/6-DISC CD CHANGER (REPLACES STD/OPT RADIO)
UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE PREMIUM SPEAKER SYSTEM
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
VB3 - CHROME STEP REAR BUMPER
VG3 - CHROME FRONT BUMPER
VK3 - FRONT LICENSE PLATE MOUNT
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V22 - CHROME GRILLE SURROUND
V73 - STATEMENT OF CERT. U.S.
XJM - P265/70R17-113S WOL TIRE
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD5 - FRONT SPRING - BASE EQUIPMENT
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR
YJM - P265/70R17 - 113S WOL TIRE
ZJP - P265/70R17-113S BW SPARE TIRE
ZY1 - SOLID PAINT
Z71 - OFF-ROAD SUSPENSION PACKAGE
Z82 - H.D. TRAILERING EQUIPMENT PKG.
Z88 - GMC TRUCK NAMEPLATE
1SZ - LD POWER PKG SAVINGS
4SA - SLT DECOR INCLUDES: *PWR FRT/PASS 10-WAY SEAT ADJUSTER *ELECTROCHROMIC ISRV MIRROR WITH COMPASS & TEMP *ELECTRIC REAR WINDOW DEFOGGER *DEEP TINTED GLASS *AM/FM STEREO W/6-DISC CD PLAYER *BOSE PREMIUM SPEAKER SYSTEM *REAR AUDIO CONTROLS *CRUISE CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY SYSTEM *OSRV MIRRORS W/PWR FOLD & ADJ, HEAT & TURN SIGNAL; ELECTRO- CHROMIC DR-SIDE MIRROR *LEATHER-WRAPPED STEERING WHEEL *FRONT FOG LAMPS *CHROME GRILLE *BODYSIDE MOLDINGS *ALUMINUM WHEELS *AUTOTRAC TRANSFER CASE
50U - SUMMIT WHITE
52I - NEUTRAL INTERIOR TRIM
522 - NEUTRAL LEATHER
6YT - COMPONENT FRT LH COMPUTER SEL SUSP
7YT - COMPONENT FRT RH COMPUTER SEL
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : YFA Traceability : 060900863
Date Scanned : 04/13/2006 Time Scanned : 03.16.00 Scan Station : 04
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : Y3R Traceability : 241950876
Date Scanned : 04/13/2006 Time Scanned : 01.58.00 Scan Station : 10
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : GY Traceability : 0BJ958288
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 6KCD Traceability : 43991634
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YNBN Traceability : 26096EDUP
Date Scanned : 04/13/2006 Time Scanned : 07.35.00 Scan Station : 05
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 7690 Traceability : 26090HWSY
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 5012 Traceability : 00031649
Date Scanned : 04/13/2006 Time Scanned : 03.42.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 8216 Traceability : 1GSE7HB
Date Scanned : 04/13/2006 Time Scanned : 05.00.00 Scan Station : 11
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 0149 Traceability : 6075JLDSE
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 0149 Traceability : 6075JLDWH
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 9601 Traceability : 9AAJD46
Date Scanned : 04/13/2006 Time Scanned : 01.58.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 5883 Traceability : 26090VZB0
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 2050151
Date Scanned : 03/29/2006 Time Scanned : 23.02.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 7233324
Date Scanned : 04/13/2006 Time Scanned : 00.11.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 07/28/2006
Delivery Type : 010 - RETAIL/INDIVIDUAL
Delivered Odometer : 0 miles
Delivering Dealer :
PO BOX 5519
(706) 549-8580
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 53509
Service Contract
SERVICE CONTRACT
Policy Number : 816074160
Owner Name : MCELROY
Description : 84/84000 GMPP MAJOR GUARD
Deductible Amount : $ 0
Inception Date : 09/07/2006
Expiration Date : 09/07/2013
Inception Odometer : 1033 miles
Expiration Odometer : 85033 miles
Summary
VEHICLE INFORMATION
Delivering Dealer :
PO BOX 5519
(706) 549-8580
Site Code : 53509
Branded Title : No
Warranty Block : No
PDI Status : Paid
OnStar Equipped No
OnStar Status N/A
XM Equipped Yes
XM Status Inactive
CLAIM HISTORY
Claim History
CLAIM HISTORY
PO BOX 5519
Site Code : 53509
PO BOX 5519
Site Code : 53509
PO BOX 5519
Site Code : 53509
PO BOX 5519
Site Code : 53509
PO BOX 5519
Site Code : 53509
Vehicle Build
VEHICLE BUILD
Build Plant : 26143
OPTION CODES
A31 - POWER WINDOWS
D07 - FLOOR CONSOLE
R6P - PREMIUM PAINT
SLM - STOCK ORDERS
YE9 - SLE/SLT DECOR
ZY1 - SOLID PAINT
50U - SUMMIT WHITE
Vehicle Component
Vehicle Component
Source Plant : N
Source Plant : 9
Source Plant : M
Source Plant : N/A
Source Plant : N/A
Delivering Dealer :
PO BOX 5519
(706) 549-8580
Service Contract
SERVICE CONTRACT
thank you so much.... sorry to be a bother, but from what you sent me, can you tell if i might could pick up on the warranty? i bought a gm warranty when i bought the truck last week.....tks ed
What do you mean when you ask.. "can you tell if i might could pick up on the warranty" ?
If you bought an extended warranty then you'll be covered for whatever the extended warranty will cover.
the warranty i got was about $1500 and good for 3 years or 24,000 miles, and &200 deductable. it is the same as the factory coverage from new. used to you could transfer a warranty for about $100. i can cancel the one i bought if i would like....tks ed
I would keep the extended warranty you bought then if your happy with what it covers,Theres nothing of the factory warranty left other than the sheetmetal "rust through" and the "Federal Emissions" warranty which covers the catalytic converter & PCM.
And today,if theres any of the factory warranty left,you do not have to pay anything to transfer it over,You don't even have to do anykind of "transfer",You just take the truck into the dealer and have the work done.
i know, but i saw on the bottom of the info of an expiration date of 9-7-2013 and miles of 85033..tks ed
That was for the previous customer who bought a "GMPP" extended warranty,It would have gotten canceled whenever he traded/sold the truck,Then he would have received a refund for the "unused" time left on the warranty.
you have been so helpful. i really appreciate all your help,info and time.i hope i can bother you again......ed
