2007 W/6" Lift, 35's, And Tpms Issues
Hi Folks,
New to the forum. I have an 07' 1500 with a Superlift 6" lift, running 18's on 35" tires. In doing so, I'm sure the TPMS somehow needs to be reprogrammed to recognize 50psi instead of 30-35psi.
Is there any way to do this myself, or does GM need to hook it up to the calibration monitor?
Thanks in advance for your help.
Nick
Hi Folks,
Nick
Hey Nick~
I have similar issues with my '08 Denali. I put 35's on 20's on and am running about 45psi in the tires. My TPMS is all whacked out too. They ONLY way they work is if I take my tire pressure down to the recommended 30-35psi, but then the truck handles like crap.
I was just at my GM dealership asking them what I can do if anything because the DIC keeps flashing errors inmy face about Check Right Front Tire Pressure etc. The sevice tech told me that "legally" they CANNOT alter the computer encoding to recalibrate the TPMS for anything other than the factory recommended pressures. I guess it all stems from the tire blowout issues that Firestone had with Ford a coupel years ago that killed someone!?
His comment was "if someone was driving with a low tire, had a blowout, rolled their truck - and god-forbid got killed / severly injured...they could sue GM or the dealership that either disabled or altered the computer which didn't properly warn the driver of the potential hazards".
On the flip-side of that conversation...the service tech said that 3/4 tons have something like a 75-80psi rating on their TPMS for towing / pulling. And there have been complaints from a few 3/4 ton owners saying that when they are NOT pulling / towing they would liek to run a lower pressure in their tires so the truck doen't ride like a tank...but they get TPMS errors when they drop below 65psi!
Long story short...he said that it is all in the computer coding and he could alter it to my desired psi...but that he would have to do it and NOT tell anyone and he woudl deny ever doing it if I had issues! He told me that the next time I have it in for service work to let him know and he woudl go in and change the settigns to my specs but wouldn't be able to doument the change anywhere 9which I can totally understand).
As far as if you can do it yourself...I'm not 100% sure of that answer...but I'd have to guess NO. I think it requires a GM computer / analysis setup to modify the PCM etc.
My dealer did this for me no problem. Charged me $65. It is set with a tech2 and is stored in the RDL module (remote door lock module). There is no liability issue when they change it according to the recommendation for tires that are on your truck. I suppose if you asked them to change it with the stock/OEM tires still on it, then it would make sense for them to deny it.
Hey Jeff...good to know that they will do it without having to "sneak" it in! So, do you still get any errors on your D.I.C. from the TPMS's? Did you just tell the service tech what psi range to set it to based on your wants / needs?
My tech made it sound liek he "shouldn't" do it...but he would if I asked him to. Maybe he was more concerned about sliding it through under warranty!?
So...if I just tell him that I want it reprogrammed to my receommended psi they will do it and keep those damn errors from annoying me! :lol:
So...if I just tell him that I want it reprogrammed to my receommended psi they will do it and keep those damn errors from annoying me! :devil:
Yep, my OEM tires nominal pressure was 35 PSI and the range is +/- 10 PSI. They cannot set the "range", they set the nominal pressure. I had right around 45 PSI in my new tires per the recommendation, so my TPMS was on the high edge of the range and would give me errors on the DIC. I had it changed to 45 PSI, so my range is now 35-55 PSI and I have not had problem since.
The techs were a little confused as they hadn't done it on a NBS truck yet, but they were more than willing and had it figured out and done within 30 minutes. I didn't even put my stock ECM/TCM in since I knew this info was not stored there, but I told them not to re-flash the ECM/TCM anyway. They said "fine" and never even questioned why I made that request. Although this was a Chevy dealer close to me, not the GMC dealer I usually have service my truck. I wouldn't have said that to them :sigh: .
i'm running 45psi in my 35's and the sensors work fine and i did nothing to them. occassionally i'll get a message that says check tire pressure, but thats it.
I run 50psi in all four tires, before the reprogram I was getting all the messages from the instrument cluster but after the reprogram everything is great and I haven't gotten any messages.
Awesome to hear everybody. I will go out and do that. I too am running 50 PSI, and the error codes are driving me nuts!
All the best,
Nick
All the best,
Nick
Hey Nick~
Nice looking rig! What size wheels / tires are you running?
Chris
looks like 35" toyo's and 17-18" moto metal 951's
Thanks for the props~
You got it! Running 18's. I liked the look vs. 20's.
Cool...I was thinking of a picture you can see the lift and all that jazz. Looks good though!
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
