Slow Power Windows
04 Burb. Man my power windows are slow. I even replaced the motor on P=side frt and its still slow. The dr. Side isgetting slower by the day. Is there any lube to put on or what ??
thanks
Scott
thanks
Scott
my passenger side is slower than the rest. when i bought it from the dealer, they had replaced the driver motor and it is fast as hell now. if it isn't the motor, not sure what it would be. lube everything?
I had that problem on my last car. I took the inside door panel off and cleaned the window tracks. Then I sprayed them with some dry silicone lube. That fixed it.
thanks
Scott
I had read the same fix nfisherman stated somewhere else on the forum before, that it was the tracks not being clean and lubed. I need to do this myself, my windows are CREEEEEEEEEPING these days.
damn hammer, musta hit the reply button 3 times. lol. My windows are slow as hell too. I can't see the tracks needing a cleaning, must need new motors i guess .... mine are slloooooowww.
Hey
see you got that Throttle body spacer on your info list. Did it really do anything or does it just look cool ?
thanks
It goes Whoo! Whoo!
Hey
thanks
it whistles at all the girls, plus adds like minimum 30 HP to the wheels..... :D ......as if. naw it doesn't do a damn thing.
Hey
thanks
At least he's honest... :lol:
Yeah lol I sure did!!! ha1 I tried to stop it but the train had left the station, Internet Explorer froze and I hit the button three times. I wonder if it gave me three posts to my count? I need to get up to 6 wrenches like Vmax2007.
What type of lube is best? I don't want to make a mess of the windows with just any lube.
Also, do you clean the black tracks the window slides up and down in, or do you clean the metal system that moves the window up and down? Or both?
Thanks.
Clean the black tracks that let the window slide up and down. After they're clean, let them dry and then apply a dry spray lube. I used Liquid Wrench Dry Lubricant. It worked well. If you use something oily, it would attract more dirt and smear the window.
While you're at it and your door is apart anyway, it wouldn't hurt to look at the lift mechanism and clean/grease if necessary.
Thanks.
Check for freying on the cable of the window regulator. I have had to replace two on my 2500 HD and one on my Denali. In all casses the windows began to go slower and slower until enough of the cable strand bunched up and stopped the windows completely. Replacement of the reg is easy.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
